How do I take the roof racks?
Old Sep 5, 2008 | 01:26 PM
motoadve's Avatar
motoadve is infamous around these parts
Any help appreciated
Old Sep 5, 2008 | 01:43 PM
motoadve's Avatar
Im mean take off
Old Sep 5, 2008 | 08:51 PM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
there are 3 screws on the inside of each rail - torx wrench or an allen wrench can work. the screws may be covered with a rubber grommet.
Old Sep 5, 2008 | 09:07 PM
canberk's Avatar
canberk is infamous around these parts
roof rails or racks?
racks can be removed by the use of the special key that comes with the racks. Insert the key, unlock the rack, remove it by sliding in the rails..
Old Sep 5, 2008 | 10:24 PM
Doravin1's Avatar
Doravin1 is infamous around these parts
I just removed my roof rails. Each roof rail has three rubber grommets. I found it easiest to pop them out with a small standard screw driver. After you pop out the grommets, you will have to unscrew the six hex screws. After the hex screws are removed just wiggle the rails and they will break free. To remove the six brackets you will need to use a torx screw driver. The torx screws are really tight so you will need a tool with plenty of leverage. A socket torx will not fit so you will have to use one with a screw driver handle. I decided to sacrifice my torx screw driver and used a vise grip on the handle to give me the added leverage needed.
Old Sep 5, 2008 | 11:22 PM
canberk's Avatar
can i buy your rails if you don't use them anymore?
Old Sep 6, 2008 | 10:47 AM
mlc.design's Avatar
mlc.design is infamous around these parts
The ones you have are roof rails
Old Sep 6, 2008 | 08:15 PM
Doravin1's Avatar
Sorry, not for sale. You would'nt want them anyway...I have a CS Titanium Edition so you would have to paint them to match your trim. All my trim is Titanium colored.
Old Sep 7, 2008 | 08:38 AM
Cpa4S's Avatar
you could sell those for a bit - i have seen quite a few people looking for that colour. i think they were fairly rare?
Old Sep 7, 2008 | 01:24 PM
Doravin1's Avatar
Yeah, I'm sure I could sell them pretty easily but I plan on switching between my rails and new racks. I'm sending the racks to the paint shop soon to be color matched in Titanium.
Old Sep 11, 2008 | 12:04 AM
johnk's Avatar
johnk is infamous around these parts
What kinds of racks did you buy?
I too have a Titanium Ed Cayenne (Silver/Blue...whatever) .... and I can't seem to find a set of decent all purpose racks.
I was thinking Thule Aero's...
Thanks!
Old Jun 25, 2015 | 11:52 AM
Zuffenhausen955's Avatar
Zuffenhausen955 is infamous around these partsZuffenhausen955 is infamous around these parts
Rails off....
What is the trick for removing the rail tabs off the slider track? Looks like the tabs has a leaf spring clip below. Ideas?
Old Sep 6, 2016 | 11:47 PM
peterbram's Avatar
peterbram is infamous around these parts
You need to find a reputable Locksmith... surely you can find one who will sell you the OEM parts you need. Apparently locksmith just doesn't want to make money!It looks like there isn't a "kit" since this isn't sold as an accessory, but you could just buy these parts and do it yourself. There won't be instructions, but it doesn't really look too complicated. Especially if there are inserts at the mounting points.
E55 Bulldog K2
Dec 15, 2015 08:38 PM
007 Vantage
Oct 8, 2015 08:35 PM
cherplex
Oct 1, 2015 08:30 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
NorthWiking
Sep 21, 2015 02:22 PM
