Photoshop help please!
I'm thinking of painting my wheels Black with a red pinstripe.
Is there anybody willing to help me out by doing a photoshop of what my Cayenne might look like?
How do you lower it below the factory setting? Will the techart module do this or do you need to replace the springs?
If you're going to add a red pinstripe you might want to consider having your calipers painted red..The contrast with the black wheel will look great !
Lowering the suspension
You can lower it with the Techart module which is the best way but will set you back two grand; or you can buy the bracket system that simply fool's the sensors regarding the actual height of the car. This is the cheapest way because it goes for about $300.00 and you can install it in less than an hour. The problem is that since it's totally adjustable many people lower the car "beyond safe limits" and then complain about how harsh the suspension is with the system installed. If you lower it within the safe margin, the suspension is only a little bit harder.
If you unplug the wire
If you unplug the wire, you are deactivating the system (I was told that by a guy that works at NYC Porsche dealer); with the brackets you are fooling the system but the air suspension is still 100% active. You can change the suspension height up and down and everything works just as it worked before installing the brackets.
mike@mautolite
Panamera Vendor Classifieds
Sep 30, 2015 05:33 PM
mike@mautolite
Sep 30, 2015 05:32 PM
mike@mautolite
Cayenne 958 Vendor Classifieds
Sep 30, 2015 05:31 PM
mike@mautolite
996 Turbo Vendor Classifieds
Sep 30, 2015 05:27 PM
