Xenon Color temp?
Old Nov 2, 2008 | 01:38 PM
crxmanror's Avatar
crxmanror is infamous around these parts
4300k
Old Nov 3, 2008 | 08:23 AM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
so yesterday I removed both front headlights ad was about to replace my low beams with 6000k bulbs. But found out that it's not doable. Hasanyome changed their low beam bulbs? If so how? The h7 bulbs I have 6000k won't fit. I was unable to remove the current h7 bulb from the plate it's attached to. How do I do tips or is it a whole piece that needs replaced?....
Old Nov 3, 2008 | 02:30 PM
Jace's Avatar
read last post ^^^^^
Old Nov 4, 2008 | 03:55 PM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
Your headlights should be D1S bulb. You don't have H7 since you have HIDs. But the high beam should be a H11.
Old Nov 4, 2008 | 08:28 PM
Vik's Avatar
Vik
Vik has a spectacular aura aboutVik has a spectacular aura about
Originally Posted by WingFlex
Stock xenon bulbs are at 4300K.
I am very picky with lights, so on all my cars I replace the bulbs with 6000K ones, which are white, rather than yellow-ish white (4300K).
You lose output with going higher than 4300K. Especially when it rains.
Old Nov 10, 2008 | 12:32 PM
katheikia's Avatar
katheikia is infamous around these parts
Got the HID kit and everything went great. About 10 minutes for each side, and no error messages. Only issue is that the 6000k HID bulbs I got are much bluer than the 4300k headlight. The supplier is willing to swap them for me. Should I do the swap???
Old Nov 10, 2008 | 12:58 PM
Jace's Avatar
what brand of bulbs did you install?
I personallydon't like the "blue" / "ricey" look.
I like the white light/stock/bright.
Choice is yours, but what brand of components are you using?
Heard GE was the best.
Old Nov 10, 2008 | 01:57 PM
ALPINE_997's Avatar
katheikia - APEXCONE?
They make a decent ballast and HID kit for the money that you just mentioned. The best kit I had in the past was CATZ but they were expensive but top notch.
I have ran APEXCONE bulbs and HID kits and no problems with them.
The DSP kits at Xenon is nice.
I like 5K bulbs as they are white with a small small hint of blue and lose just under 6% of the lumen output compared to about 15-20% with the 6000K.
Old Nov 10, 2008 | 01:59 PM
ALPINE_997's Avatar
jace - use a 5000K Philips HID bulbs. Its very white with very good light output.
Old Nov 11, 2008 | 06:30 PM
vroom's Avatar
vroom is a glorious beacon of lightvroom is a glorious beacon of lightvroom is a glorious beacon of lightvroom is a glorious beacon of lightvroom is a glorious beacon of lightvroom is a glorious beacon of light
Do you guys realize that when you install both same temp. HID (eg. 6000k) on the low beam and fog light. It will always look bluer on the fog. I found mine and my friend's to be like that. Is it because of the projector that makes the difference?
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
BlackMarketRacing
Dec 8, 2015 01:49 PM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
Wheel Experts
Wheels/Tires
Aug 19, 2015 09:05 AM
