Audio Experts Help
Old Dec 10, 2008 | 08:29 PM
04CS's Avatar
04CS is infamous around these parts
Audio Experts Help
I have been told that if you remove the stock radio from Cayenne (I have 2004 Cayenne S) in order to install an after market nav unit it can cause the electronics to fail throughout the car. I am thinking about pulling out the stock headunit (was standard cd player not the nav option) and putting in a pioneer double din nav screen. Has anyone experienced this type of failure of glitches in their systems?
Old Dec 11, 2008 | 09:41 AM
CayenneTurbo77's Avatar
CayenneTurbo77 has a spectacular aura aboutCayenneTurbo77 has a spectacular aura about
No chance!!
The shop I use has replaced well over 100 stock units with aftermarket components.....and not one customer reported any electronics issues....
I know in my case, I have had NO issues
Old Dec 11, 2008 | 03:47 PM
Precision's Avatar
Precision is infamous around these parts
Absoultely not true, I have installed numerous aftermarket nav systems in Cayennes from "04s to '08s with no problems at all.
Old Dec 11, 2008 | 04:05 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Let me add on this... is there a clean way to use aftermarket amps and speakers but still use the factory Nav unit? (CTT 04)
David
Old Dec 12, 2008 | 12:04 AM
David
100%
I gutted my bose system minus the head unit and ran it like that for over 3 years.... the factory navi is nice but the sound quality doesnt compare to aftermarket setups.....
Check out this thread:
https://www.6speedonline.com/forums/...questions.html
Old Dec 12, 2008 | 12:10 AM
PORSCHEAUDIOLUV's Avatar
PORSCHEAUDIOLUV is infamous around these parts
David
There are sevral option to retain the factory head unit and still do a great sounding system. You can use a rockford 360.2 ; or an audio control LC6 / LC8I ; or you cna even do the alpine pxe-h650 imprint processor.
I also have sone mutilple systems in cayennes and 997 , 996 , caymans also w/ no problems.
Let me know if you need anything done.
Thanks , PAUL
Pattarchi@al-eds.com
Old Feb 20, 2009 | 11:12 AM
intheflesh's Avatar
intheflesh has a spectacular aura aboutintheflesh has a spectacular aura aboutintheflesh has a spectacular aura about
Hey gang.
I search for threads on audio installs because I am about to o one myself (through a shop).
There are 'clean' ways to keep your factory HU and bypass the bose system. For those that dont know, the bosesystem uses optical outputs which makes it a little difficult to tap into it, unless you use LOCs after the amplifier (doing this 'colors' the sound since the signal is already amplified. all the signalsbefore the amp are digital, so you cant use an LOC like you could in other cars.)
I am waiting for a MOSTbus adapter to produced that will be able to tie in with the factory HU and send a signal to an after market amplifier. I forget the brand that makes it, but they make an Ipod/Bluetooth interface as well. The MostBus output isnt supposed to be out for a fewmonths, but luckily my local audio shop is buddy buddy with the company, and they are sending me the proto-type and it should be here in a few weeks.
edit: mobridge is the company i was thinking of
Old Feb 22, 2009 | 02:15 AM
stikystikyricky's Avatar
stikystikyricky is infamous around these parts
Your good.. Seen it done many times at work!
Old Feb 23, 2009 | 09:42 AM
mostring's Avatar
mostring is infamous around these parts
Nav TV has a MOST adaptor to install an aftermarket headunit and it will retain all factory components(amp,speakers and so on)
nick49
Sep 13, 2015 05:46 PM
jpik2003
Sep 10, 2015 05:18 PM
