Cayenne Oil Change
Old Dec 11, 2008 | 01:30 PM
BD 997's Avatar
BD 997 is infamous around these parts
Cayenne Oil Change
Hey guys... my wife has a '08 Cayenne V6 and so I was wondering when the first oil change is recommended by Porsche...
Old Dec 11, 2008 | 02:12 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
13000 I believe.
mobile 1
Old Dec 11, 2008 | 02:32 PM
canberk's Avatar
canberk is infamous around these parts
change it every 5000 miles, you have nothing to lose if you change it more often than the factory recommendation and it won't cost you a fortune if you just go to jiffy lube or anything like that..
Mobil 1 0W-40 ( You can find the oil at walmarts, and can change it yourself. I think I've seen an easy oil change solution on Skymall, that requires no experience or going under the car, when I was flying back home )
Old Dec 11, 2008 | 04:23 PM
cayenned's Avatar
cayenned has a spectacular aura aboutcayenned has a spectacular aura about
haha, yeah I saw that too! didn't read it though
Old Dec 11, 2008 | 08:34 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
This is very good advice. Just because you CAN go 10,000,20,000 or however many thousand some manufacturer's claim on an oil change does not mean you should. Cheap insurance against any possible issues. I have seen turbo exhaust impeller/turbine wheel break apart from each other due to neglected oil changes, variocam solenoids can get clogged with sludge if let go too long. Mind you, I'm not talking 1,000 or 2,000 miles over, but it can happen.
Old Jan 13, 2010 | 08:12 PM
imtheprez's Avatar
imtheprez is infamous around these parts
Whats cost of oil change at jiffy lube or somewhere similar?
Old Jan 13, 2010 | 08:24 PM
zmw's Avatar
zmw
zmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to behold
I for one plan on FULLY going 20k miles on my 04 CTT, it's under warranty and when it's not - I'll be getting rid of it anyway. 10 qts of synthetic on a full drysump shouldn't need more than that anyway, you call it cheap insurance, i call it wasted money - the issue with not changing it is just making sure you're checking your oil and are not letting it get low...
even after 20k miles my oil looked clean - shrug. do it more often if you want, but I'm pretty sure porsche is not recommending long interval oil changes just to break their cars.
Old Jan 13, 2010 | 08:31 PM
bbywu's Avatar
Have you ever watched an oil change being done at a Jiffy Lube?
http://www.youtube.com/watch?v=LGa34gYfYzk
Old Jan 14, 2010 | 12:45 AM
Road Runner's Avatar
Road Runner is infamous around these parts
[quote=bbywu;2687203]Have you ever watched an oil change being done at a Jiffy Lube?
Nice one!
Old Jan 14, 2010 | 12:42 PM
LIL RAJA's Avatar
LIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant future
[quote=Road Runner;2687435]
Nice one!
lol. WTH? how do u miss that one?
Old Jan 14, 2010 | 07:00 PM
Jace's Avatar
when I checked around for my GTS, noone would actually touch it because of its cost.
I ended up taking it to the dealership and buying the mobile 1 myself. saved about 30 bucks for buying it myself. I think their cost for the labor was 70 bucks.
worth it to have a porsche dealership do the job.
Old Jan 15, 2010 | 09:51 AM
pcst's Avatar
pcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the rough
especially they reset the warning msg on your dash...
i need to get the tool, forgot the name, since i do most of jobs in my garage...
Old Jan 16, 2010 | 09:56 PM
Durametrec is the name of the tool you need!
Old Jun 3, 2010 | 01:47 PM
Brentis's Avatar
Brentis is infamous around these parts
Will Porsche reset it for you if you ask them to? My car is out of warranty, so don't see the point and want to do my own service.
Old Jun 3, 2010 | 03:16 PM
medtech's Avatar
medtech is infamous around these parts
This is an EASY DIY, and if you get the oil on sale you could do it for about $80. Order the parts from Sunset or Suncoast, and buy name brand synthetic oil in any recommended weight. It takes longer to get the protective covers off than it does to change the oil.
In general I would NOT recommend sucking the old oil out the dipstick b/c you will always leave oil and sediment behind.
These engines do fail. I personally change mine every 5k.
You CANNOT tell whether an oil has broken down by looking at it, you have to send it out to a lab (ie., Blackstone Labs) in order to get it analized. If you are looking to push the oil change interval to 10 or 20k, that's the only safe way to do it. Of course if you change oils, then you would have to get it re-analized.
I've seen uber expensive/fancy racing oil that won't hold up past 5k, so cost doesn't equal longevity.
Jiffy Lube is NOT an option unless you find one that will let you bring your own parts and oil. (they won't stock your filter, plug, or washer). Plus, I wouldn't trust them not to screw it up, or switch oils on you.
Find an Indy mechanic, or DIY.
