Electrical issue with the bulbs in an 04 Cayenne Turbo
Old Dec 24, 2008 | 09:06 AM
wolfz's Avatar
wolfz is infamous around these parts
Anyone now the fix to reoccurring front turn signal malfunctions on the Cayenne 04 Turbo. I have replaced the blub twice however it works for a few hours and is out again. Blub is fine and is the correct voltage. Then the other lights start having problems like the high beams and sidelights.
Old Dec 24, 2008 | 09:07 AM
NorthVan's Avatar
Maybe a faulty relay, or perhaps a ground issue.
Old Dec 24, 2008 | 02:34 PM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
I have the same issue with mine. But it's because the headlight assembly wasn't fully pushed "in" for a solid connection to the plug in the back of it. I may shim mine or something to move it up or try to tweak the terminals in the plug so it grabs the pins better perhaps. Just get out and give the whole assembly a shove and see how it reacts. I thought I had other problems but it was just that simple in my case.
Old Dec 25, 2008 | 12:43 PM
ErikG's Avatar
ErikG is infamous around these parts
Identical problem, mine is the right side only. Was going to eventually bring it back to the dealer before warranty expires. When I removed the headlight before, it looked like "they" had messed with the headlight unit before. (bought the CTT used)
Old Dec 25, 2008 | 06:30 PM
cayenned's Avatar
cayenned has a spectacular aura aboutcayenned has a spectacular aura about
+1 sometimes you get a fault message when all it is is that the headlight casing has to be pushed in a bit for a proper connection. One time I hit a pretty big pothole and both headlights when out. Got out, pushed them it, and both worked fine.
Old Dec 27, 2008 | 12:23 AM
bullonwallst's Avatar
bullonwallst is infamous around these parts
I cannot believe that is all it is... I have the same thing happening right now. I first had a problem dipped beam...
Then followed instructions and took the headlight out and tightened down the frame on the light assembly.
The problem is now solved and then the front right or passenger side blinker is now throwing a code and not working.. then working...etc.. It also seems to go out more when its cold, but at least the light still works
Well when I put in my new D1S 12000k lights I will try to do the pushing in hard to get a good connection...
Does anyone know what comes standard for the headlights on the 955 Turbo...?
Old Dec 27, 2008 | 12:53 PM
huskyfan23's Avatar
huskyfan23 is infamous around these parts
4300k most likely. 12000k is ridiculous. You'll get a terrible light output.
Old Dec 27, 2008 | 05:59 PM
have2modit's Avatar
have2modit is infamous around these parts
have a 2005 Ctt and i am always having bulb problems. Cornering lights and signal mostly
Old Dec 28, 2008 | 09:39 AM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
There have been issues with the headlight mounting cradles becoming loose, and this will cause lots of intermittant problems. Some also can become deformed and must be replaced to perform correctly. One issue with the turn signal that has been known and updated is the bulb holder for the turn signal. Bulb is fine, but the holder can lose contact with the headlight and cause issues. Have also seen some low beam bulbs start flickering on cars with the HID lights. This will also cause an intermittant Dipped beam warning.
Old Dec 28, 2008 | 01:21 PM
Anything on recalls for this problem? What does it take to get a recall?
Old Jan 1, 2009 | 09:34 PM
SCvet00's Avatar
SCvet00 Is a GOD !SCvet00 Is a GOD !SCvet00 Is a GOD !SCvet00 Is a GOD !SCvet00 Is a GOD !SCvet00 Is a GOD !SCvet00 Is a GOD !SCvet00 Is a GOD !SCvet00 Is a GOD !SCvet00 Is a GOD !SCvet00 Is a GOD !
put the 12k's in today... they are great to say the least... The dipped beam deal has not came back on in awhile since I tightened down the housing , but now the right front blinker doesn't work all the time and goes out very very frequent
Old Jan 8, 2009 | 01:37 AM
AJ997S's Avatar
AJ997S is infamous around these parts
I've just lately started having the same issue. Replaced many bulbs in both headlamps in the last month alone! Tightened down everything today hopefully this will help. Great info guys thanks!
socialpro
Cayenne 958
May 18, 2016 09:58 AM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
