Squeaky Steering Wheel
Old Dec 26, 2008 | 05:09 PM
nemisis's Avatar
nemisis is infamous around these parts
Happy Holidays, proud owner of a 2006 Cayenne here, my 3rd Porsche in 3 years, my wife is ready to kill me Loving this SUV, only issue is a squeak in the steering wheel when turning right or left. Sounds like metal on metal, any suggestions?
Old Dec 27, 2008 | 12:33 AM
bullonwallst's Avatar
bullonwallst is infamous around these parts
I have not had that problem on the 955 turbo just yet and hopefully never, but did have the problem on my CL Mercedes and it was the Rack and Pinion.
But could be that or power steering pump?
Old Dec 27, 2008 | 02:40 AM
canberk's Avatar
canberk is infamous around these parts
I've had that problem once but it cleared itself..
Old Dec 27, 2008 | 08:30 AM
nemisis's Avatar
Appears the squeak may be occuring during slow turns after the tires have warmed up a bit. The sound is like a wet sneaker on the floor, annoying as hell
Old Jan 5, 2009 | 02:46 PM
nemisis's Avatar
Dealer adjusted steering column damper, did not correct the issue....next step rack and pinion replacement, good call bullonwallst!
Old Jan 6, 2009 | 08:21 PM
stealthn's Avatar
stealthn is infamous around these parts
There was a TSB (6954) for grinding which was the rubber tube on the centering pegs of the airbag contact unit, and the fix was to grease them. It did say grinding not squeeking, so I'm not sure if it's the same issue.
Bob
Old Jan 7, 2009 | 05:23 AM
nemisis's Avatar
Quote from RFM at Renntech.org:
"Concerning steering squeaks on Cayenne:
1/ Rubber part where the steering column go's trough the car floor can produce squeaks: a treatment with silicone spray is recommended.
2/ under the car, where the steering column is connected to the steering rack sits a round plate and seal, which protect the steering pinion against dirt, water, etc. ( the steering rack is a pinion and rack system ) some of the racks have a little water infiltration and the pinion starts squealing after a year or so. The only solution against that, till now, is a steering rack replacement as your dealer suggest."
Old Jan 15, 2009 | 03:06 PM
nemisis's Avatar
Dealer replaced the power steering rack, including the steering gear, part: 955-347-011-17 and the steering column sealing sleeve, part: 955-347-037-03
Drive is MUCH improved, nice "new car" stiffness, plus, it appears the noise is gone (fingers crossed)
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
Michael_s
Sep 11, 2015 08:03 PM
no1joey
Sep 2, 2015 12:32 AM
Zero911
Aug 24, 2015 06:51 PM
