How do you remove Cayenne lettering / emblem?
Old Feb 24, 2009 | 03:54 AM
mikhail1's Avatar
mikhail1 is infamous around these parts
Question How do you remove Cayenne lettering / emblem?
Does anyone here know a safe way in how to take off the acutal Cayenne lettering on the rear trunk? (My vehicle is black, if that makes a difference)
Thanks!
Mikhail.
Old Feb 24, 2009 | 07:14 AM
two-five LGT's Avatar
two-five LGT is infamous around these parts
Use dental floss or fishing wire, slide it behind the emblem and begin separating the emblem from the body panels. When done, use GOO GONE to remove the glue residue from the body. Good as new!
Old Feb 24, 2009 | 07:16 AM
Gramicci101's Avatar
Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !Gramicci101 Is a GOD !
Also, a hair dryer on the lettering will help to loosen the glue first.
Old Feb 24, 2009 | 07:18 AM
porscheaudifam's Avatar
porscheaudifam is infamous around these parts
I used a lilttle heat from the wife's hair dryer and puleed off no problem and then GOO GONE as he says.
Then I reapplied wax/polish since I was not sure what the GooGone did to the protection.
Old Feb 24, 2009 | 09:41 AM
strife_wy's Avatar
strife_wy has a spectacular aura aboutstrife_wy has a spectacular aura about
You can also get the residue off without GOO GONE.
I used a bit of rubbing alcohol and car polish - achieved the same result.
Old Feb 25, 2009 | 01:11 AM
mikhail1's Avatar
So how hot do you heat this baby?
Old Feb 25, 2009 | 09:15 AM
I've done it with and w/o heating up the emblem/glue first, it'll just take a bit longer w/o as the glue is not as soft and pliable. You could blow on it for maybe 2 mins until the emblems are warm to the touch.
socialpro
Cayenne 958
May 18, 2016 09:58 AM
Qu4ttro
Cayenne 958
11
Sep 4, 2015 01:35 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
