owners of 2ndary Catbypass Pipes....
Old Feb 27, 2009 | 09:09 PM
christx997's Avatar
christx997 is infamous around these parts
so im thinking about getting some 2ndary Catbypass Pipes. I have seen and heard all the videos out there. but i have never heard any clips inside the vehicle. so my question is to the owners out there, is this catbypass a pain in the cabin? i had some on a 997c2 and it was annoying after awhile.
Old Feb 27, 2009 | 10:36 PM
copasetic222's Avatar
copasetic222 is infamous around these parts
I've had Fabspeed cat bypass pipes and mufflers since I took delivery of my '09 Turbo S in September and can't imagine the vehicle without them.
Old Feb 28, 2009 | 12:59 PM
katheikia's Avatar
katheikia is infamous around these parts
Not at all, these trucks are very well insulated.
Old Feb 28, 2009 | 02:49 PM
christx997's Avatar
thanks for the info guys.
Old Feb 28, 2009 | 06:32 PM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
Go for it!! I have the bypass pipes and custom exhaust installed on my CTT and there's zero drone.
Old Feb 28, 2009 | 07:20 PM
bonemechanic's Avatar
bonemechanic is infamous around these parts
I had installed them a while back. In the cabin you can't tell the dif. If you stand behind the pipes there is a nice improvement in the rumble .especially when cold starting. Other than that I think that it still needs a bit more. Cartgraphic makes a "not so noisy" cat back system..
Old Feb 28, 2009 | 09:10 PM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
It doesn't take anything away in the cabin at all. I really didn't think it added that much sounds until I drove with the windows down one day. For me, I don't really want anything loud so I really like the mod.
Old Mar 1, 2009 | 11:42 AM
TCM's Avatar
TCM
TCM is infamous around these parts
The cat bypass add almost no drone outside of immediate startup. You will love the modification.
Old Mar 1, 2009 | 01:23 PM
atlshaver's Avatar
atlshaver has a spectacular aura aboutatlshaver has a spectacular aura about
I have the insulated glass and there is no drone.
Old Mar 1, 2009 | 02:35 PM
canberk's Avatar
canberk is infamous around these parts
i remember that there was a guy who was complaining about some kind of metallic sound coming from his exhaust after the mod, is that for real? is it annoying? is the sound better than the stock exhaust system or worse?
Old Mar 1, 2009 | 03:01 PM
TCM's Avatar
TCM
The only metallic sound you will receive is in the first 10 seconds of a cold start until the metal gaskets expand from heat and stop rattling. Other then that, if you hear any metallic banging, your pipe is hitting the cross member bar and can be easily adjusted up. Sounds much better then the muffled stock system.
Old Mar 1, 2009 | 03:38 PM
christx997's Avatar
hmm, about to pull the trigger....can you really notice rattling in the beginning?
Old Mar 1, 2009 | 04:24 PM
Jeff SD's Avatar
I have zero rattling.
Old Mar 1, 2009 | 07:33 PM
atlshaver's Avatar
No rattling here.
Old Mar 1, 2009 | 07:36 PM
christx997's Avatar
thanks for all the info guys, greatly appreciated
