Best snow tires?
Old Oct 5, 2004 | 12:00 PM
DEETZ's Avatar
GO 6SPEED!
DEETZ is infamous around these parts
Best snow tires?
Has anyone tried any of these tires? Which one performs best for winter(snow)? I don't need those tires for summer
thanks alot
Pirelli Scorpion Ice & Snow
Dunlop Grandtrek WT M2
Continental 4X4 WinterContact
Bridgestone Blizzak LM-22
Old Oct 5, 2004 | 12:03 PM
DEETZ's Avatar
GO 6SPEED!
Is it worthed to upgrade to those snow tires? I live in Boston... I have the Turanza 255/55/18 with 12k miles on it
Old Oct 5, 2004 | 12:33 PM
TT's Avatar
TT
TT is a glorious beacon of lightTT is a glorious beacon of lightTT is a glorious beacon of lightTT is a glorious beacon of lightTT is a glorious beacon of lightTT is a glorious beacon of light
Why dont you just keep the 22's on :P LOL just playin!!
Ryan T.
Old Oct 6, 2004 | 01:39 AM
Jenner's Avatar
Jenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud of
Dunlop Grandtrek WT M2 in 235/60/18
Old Oct 6, 2004 | 05:33 AM
damon@tirerack's Avatar
Moderator
If you have never driven on dedicated snow tires, you would not believe the difference. It's night and day. Really. Even if you don't get much snow, It's still cold. When a summer tire gets too cold the rubber gets hard and the traction of the tire goes completely south. Snow tires are very soft and have many sipes in the tread design. These sipes create thousands of biting edges that grab the ground to provide great traction regardless of the temperature. The Turanza's will be very slippery on the ice when they get cold.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Oct 6, 2004 | 07:47 AM
DEETZ's Avatar
GO 6SPEED!
Damon: thanks for the explanation, it didnt perform that great last winter... what tires do you recommend from all those 4?
Old Oct 6, 2004 | 08:12 AM
ESK's Avatar
ESK
Hick from NH
ESK is infamous around these parts
Deetz,
I has the Dunlops last winter and they performed tremendously in snow or icy conditions. And, on dry pavement they ride as good as an all season tire. You won't even know you have snows on. You almost be tempted to leave the 22s off the ride is so good!
Eric
Old Oct 6, 2004 | 09:16 AM
DEETZ's Avatar
GO 6SPEED!
ok I am ordering the Dunlop I heard the Bridgestone isn't that good.
Old Oct 6, 2004 | 08:52 PM
Jenner's Avatar
*cough cough*
Old Oct 6, 2004 | 11:02 PM
Moderator
Dunlop or Bridgestone, you cannot go wrong. Personally - I would buy the Bridgestone. They have a higher silica content than the Dunlop for added traction. I drive them, and so does everyone else here. Both meet the industry's highest snow/ice standards. You decide, either way the traction is MUCH better.
Call me with any more questions or link through here to order.
damon@tirerack.com
Or use this link:
Old Oct 6, 2004 | 11:46 PM
DEETZ's Avatar
GO 6SPEED!
One last question, should I follow Porsche approved winter tires? that means I have to get the Pirelli 255/55/18 if I want 255. Or 235/60/18 for the Dunlop. Honestly, I like the dunlop and it is not that expensive.
Old Oct 7, 2004 | 08:07 AM
TCM's Avatar
TCM
TCM is infamous around these parts
DEETZ:
You can get 255/55/18 for any of the aforementioned tires. They are all available in that size.
Old Oct 7, 2004 | 08:34 PM
Moderator
I'd call the stealership first and make sure they are not going to be snobs about it. Some won't do any warranty work on the wheels/tires if they are not N-spec rated. I'd buy the 235 regardless. A narrower, taller tire ALWAYS works better to get through the snow than a wider one.
damon@tirerack.com
Or use this link:
Old Oct 12, 2004 | 08:22 PM
PaulW's Avatar
PaulW is infamous around these parts
Narrow vs Taller
The 235 is not taller than the 255, just narrower.
Old Oct 12, 2004 | 09:27 PM
Jenner's Avatar
Specification Sidewall Radius Diameter Circumference
255/55-18 5.5in 14.5in 29.0in 91.2in
235/60-18 5.6in 14.6in 29.1in 91.4in
Actually PaulW you are wrong. As you can see the 235 is taller.
danyoP4S
Sep 30, 2021 05:06 AM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
oo7
Sep 10, 2015 08:08 AM
WheelB
Sep 3, 2015 10:26 AM
gabe325
911
Sep 2, 2015 08:10 PM
