time for amp/sub upgrade
Old Apr 30, 2009 | 07:04 AM
NavyNupe's Avatar
NavyNupe is infamous around these parts
Awesome! I have a base '06 with CDR and I wanted to add an Alpine amp. Is that a 4 or 5 channel? Is a 5 channel needed to keep the CDR, add new speakers, and a JL Clean Sweep? I don't want to get ripped at installation. Thanks for your advice.
Old Apr 30, 2009 | 10:29 PM
ryan79's Avatar
ryan79 is infamous around these parts
Here's a similar solution for bass.. note the sub was built for my previous vehichle and it is not goint to stay there. It's going to be side mounted in the side cargo area (the area will have to be built out some and re-carpeted - not a big deal - to fit the subs depth and box sq/ft)
Old May 1, 2009 | 03:06 PM
amalamud's Avatar
amalamud is infamous around these parts
ryan, looks very neat but how about the spare?
Old May 1, 2009 | 05:24 PM
ryan79's Avatar
I didn't have a spare to begin with.. so nothing lost really.
Old May 1, 2009 | 08:03 PM
lovethesport's Avatar
lovethesport is infamous around these parts
what sub and box is it----
Old May 1, 2009 | 08:25 PM
ryan79's Avatar
Custom box. JL 10w7.
Old May 3, 2009 | 08:28 PM
bmwm506's Avatar
bmwm506 is infamous around these parts
Looks Great
Old May 4, 2009 | 07:36 AM
very nice---is the 10 good enough or would you have gone to 12 or 13
Old May 4, 2009 | 09:53 AM
ryan79's Avatar
I think the 10w7, w/ proper enclosure and power, is one wicked sub.
If I wanted a pure "boom" system - I'd have went a different direction. Probably 2 12's or a 13".. but the 10" is really the best of all worlds for my set-up. It can shake the ride and make you hair vibrate (tickle your head) if you want to push it, but at low volumes it hits when it is supposed to and with precision and stops with precision.
I will say that I am happy i got a new amp for it when I switched cars. I was feeding it 500w (optimal zone) but have upped it to 750 (its max) with the JL 750/1 HD. It's an awesome combination!!
I wouldn't see a need for a 12 or 13 unless you're looking at making things outside your car shake.. but lets face it, bass is addictive and the 10 puts out plenty of bass.
Old May 5, 2009 | 08:24 PM
thanks
Old May 6, 2009 | 02:13 PM
mattjtaylor50's Avatar
mattjtaylor50 is infamous around these parts
i am thinking of doing the same setup as reborn996
would this setup work:
http://www.bestbuy.ca/catalog/prodde...10&catid=20118
i think it is the same amp.
thx MT
Old May 6, 2009 | 02:38 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Matt, that is the same amp I am running but not the same box or speakers... although that kit looks decent and the price is right. I say go for it!
David
Old May 6, 2009 | 03:38 PM
thanks d
i decided i might try the JL stealth box but found out i don't have space because i have the 4 zone AC option.
i am taking my car into audio shop for mobridge install and they are going to figure out what i can do for subs.
Old May 30, 2010 | 02:47 PM
ryan79's Avatar
Update on the 10w7 being side mounted as described earlier in this post.
The bass from this is tremendous; a nice improvement over the box -- plus freed up a lot of room.
Old Dec 1, 2010 | 04:33 PM
cordsig79's Avatar
cordsig79 has a spectacular aura aboutcordsig79 has a spectacular aura about
Originally Posted by Reborn996
Sometimes I am too nice a guy... just ran out and took some pics for you!
As you can see it fits fine under the factory spare!
Image Dynamics 10" sub in custom box, easy to take out when needed!
Heck, here are some pics of my XM Radio install using a Dension Gateway 500 interface just for good measure!
I have the I-pod cable run up into the non-smokers tray in the front dash as well so its easy to swap out I-pods and use them for control. Rest of the factory system is stock for now.
David
Hey guys if I have the base CDR-23, and no bose, is there even an amp under there to do the conversion?
