oil changes
Old Sep 28, 2009 | 02:30 PM
dano_S's Avatar
dano_S is infamous around these parts
oil changes
hey guys,
just wanted to see where and how often you guys change your oil, i've got a 2006 CS myself, and am thinking about doing it myself....what say you?
Old Oct 1, 2009 | 02:00 PM
lovethesport's Avatar
lovethesport is infamous around these parts
it is a very easy diy---you will need a reste tool or go to the dealer to have light reset----
Old Dec 21, 2009 | 02:07 PM
qooldude's Avatar
qooldude is infamous around these parts
Exactly. Did it myself a year ago, about 7,500 and getting ready for another one. Easy DIY.
Old Dec 21, 2009 | 05:57 PM
DUTCH VanAtlant's Avatar
DUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud ofDUTCH VanAtlant has much to be proud of
If I ever get mine back from service (day 18 out of 54 ownership days), it will get this done at about 2,500 miles. Then again at 5,000 and every 5,000 thereafter - or until I sell the car.
Old Dec 21, 2009 | 06:49 PM
bbywu's Avatar
Originally Posted by dano_S
hey guys,
"What say you?..."
Ahhh...a Bill O'Reilly fan!
Easy DIY. Two hex drain bolts. Aluminum bolts...ie very soft, easy to strip...and really **** you off in the most inopportune time. Like the previous owner did on this:
Do not over tighten. Do not use an Allen key. Do not use use a Torx bit. Use a hex bit and a socket wrench. Otherwise you'll be stuck doing this:
Replace the crush rings.
8.5 quarts on the money.
Old Dec 21, 2009 | 11:25 PM
dano_S's Avatar
you know, I didn't even realize i picked that up from O'reilly....
thanks for the info!
-d
Old Dec 28, 2009 | 08:55 AM
I just did my Transsyberia this past weekend. Details here:
http://www.renntech.org/forums/index...0&#entry163791
I used Redline 5W40, which I feel is far superior to that dishwater thin Mobil 1. It might just be a Placebo Effect, but I am already noticing better fuel mileage and slower warmup for the oil (less friction?) since the change. YMMV.
Old Dec 28, 2009 | 10:59 AM
zmw's Avatar
zmw
zmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to beholdzmw is a splendid one to behold
Under most circumstances I'd agree with you - but I have to believe that Porsche has done more R&D than either you or I when choosing an OEM oil, while I would agree mobil 1 is on the bottom of the list that I would choose when SWITCHING to synthetic, if it's the synthetic that porsche chose to begin with (and it is) than there has to be a reason for it.
Do some research on mobil 1 and acura RDX engines, the thicker synthetics have somehow been linked to spinning the bearings on the 4th and the RDX is certified to run only on mobil 1... May not be the same issue on the CTT just saying there are reasons other than marketing that vendors pick oils ranging from detergent level to viscosity to anti foaming....
And isn't the oil change interval something retarded like 20k miles on the CTT because of the 12 qt dry sump?
All I'm saying is be careful.
-Z
Old Dec 28, 2009 | 12:06 PM
-Z
Thanks. In addition to your arguments, follow the money. How much they pay for the oil in bulk at the engine plant also might have some serious consideration.
I'll stick with a brand that I and many other folks trust; and that's Redline. As far as 20k service intervals on the 9 qt sump GTS engine, I'll go for the overkill and do it every 5k w/filter. Cheap insurance.
Old Dec 29, 2009 | 01:50 AM
Road Runner's Avatar
Road Runner is infamous around these parts
Every 5K?
You are taking a huge chance, I change my oil and filter every weekend regardless of the mileage!
Just kidding!
How much do you think the bulk price difference is between Mobil 1 and Red Line?
My guess is that Porsche is saving less then $15 per vehicle by using Mobil 1 over Red Line.
If Red Line is so much better, do you really believe that Porsche would purposely compromise their reputation and warranty program to save less then $15 on a $100,000 vehicle!
Old Dec 29, 2009 | 05:34 AM
One of the nice things about this world is that there are different brands for different buyers. I'm happy with my choice, as you seem to be with yours. Enjoy your ride!
Old Dec 29, 2009 | 10:41 PM
That is very true.
Thanks and enjoy your ride too!
Old Dec 30, 2009 | 09:52 AM
Pepper's Avatar
Pepper is infamous around these parts
Thumbs down Which weight Mobil 1?
04 CS 63k miles, N Fl
Old Dec 30, 2009 | 12:22 PM
0W40 or 5W40
Old Dec 31, 2009 | 04:33 PM
Pepper's Avatar
What size in mm is the hex bit we need for the drain plug?
