How important is the coolant pipe upgrade on an 04 Cayenne TT?
Old Nov 17, 2010 | 02:19 PM
  #31
TenaciousT's Avatar
TenaciousT is infamous around these parts
Originally Posted by BLKPPR
Based on some posts above is this ussually/always a dump of coolant or can it start out slow? I noticed on my 47k mile 06S that there have been small trailing puddles under my car the last 3 days inside of the left front passenger tire (about 1 1/2 feet from the tire). Doesn't taste or look like coolant (it's clear and relatively odor free) but it hasn't been there before. Any thoughts? I drive quite a bit and don't want my family and I stranded on the side of the road during the holidays.
I had this same symptom and turned out to be my water pump at 50k miles.
Old Nov 17, 2010 | 02:37 PM
  #32
snzuloz's Avatar
snzuloz is infamous around these parts
If you have tasted it you would know whether it was coolant or not, coolant is very sweet to the taste, I'm not sure where the a/c loses it's condensation from, maybe this is it? Best to lift it up and have a look around, check your levels etc, so you won't have a failure down the road.
Old Nov 17, 2010 | 03:00 PM
  #33
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
Originally Posted by VTGT
^What is the average labor cost on this.
Can you ever get a Porsche dealer to do this Pro Bono, seems to be a pretty widespread issue. Should be a recall............I have seen this kinda crap on most
Manufacturers.
Somebody needs to get hurt b/f they'll issue a recall...
Old Nov 17, 2010 | 03:04 PM
  #34
SeattleBum's Avatar
Originally Posted by Bigbuzuki
SeattleBum,
Can you advise us of the part numbers for the manifold coolant lines that failed inside your intake manifold.
The part numbers of the replacement new steel braided lines you had fitted would be good to know of as well.
Thanks.
I wouldn't have the faintest clue on the part numbers. I just had the car towed to the dealership and got it back a couple of days later with my pocket about $1800 lighter.
Old Nov 17, 2010 | 10:29 PM
  #35
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
Part numbers should be on the dealers invoice.
I agree with post number 15, there are no coolant lines inside the manifold or 'steel braided hoses'.
It would be good to know if these modded hoses do actually exist.
Old Nov 17, 2010 | 11:53 PM
  #36
gr8ful's Avatar
gr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to allgr8ful is a name known to all
Originally Posted by JSCyneS2
I was going 15mph coming up to a stop light and my entire coolant just dropped. Just got off the phone w/ porsche and obviously they don't stand by their product. They completely upgrade the coolant system from a three-pipe plastic to a 2 pipe metal (have to use a saw to cut out the old plastic pipes) and they will not admit that they had faulty engineering. From a brand like Porsche this is unacceptable and with the service I just received from them on this matter will question my next purchase
Porsche refuses to prevent damage by taking care of this. I am mad at them too. I wrote their VP of marketing back in early October. While Porsche is willing to spend big bucks on advertising, they aren't willing to pay for a postage stamp to respond to my letter.
Old Nov 17, 2010 | 11:56 PM
  #37
gr8ful's Avatar
Originally Posted by Reborn996
Be forewarned, if you wait till the pipes burst and coolant covers the motor and transmission you can have more expensive repairs later. When mine went it took with it the transmission seals 48 hours later and I was told by the dealer that since the starter is right under the pipes it usually will fail shortly after as well.
Yes, it's a friggin' time bomb. The latest Excellence has an in-depth artilce on Cayenne problems this issue. Get it!
Old Nov 17, 2010 | 11:58 PM
  #38
gr8ful's Avatar
Bad idea to ingest POISON!
Old Nov 18, 2010 | 07:59 AM
  #39
snzuloz's Avatar
If you die from tasting (not swallowing here) a very small amount of whats there to determine what it is then you were headed for the ground already... You can spit it out as soon as your taste buds tell you whats going on, just my thoughts as it sometimes is hard to tell what it is if it's diluted.
Old Nov 18, 2010 | 09:55 PM
  #40
RobsCountach's Avatar
RobsCountach is infamous around these parts
How Does One Know ? Where to Look ?
If you open the hood, its all engine covers and side covers. As I've recently picked mine up, I'd like to know where's the quickest place to check if mine are plastic time bombs or Metal !
Old Nov 19, 2010 | 02:54 AM
  #41
SeattleBum's Avatar
Well, someone posted otherwise, but I have always been told you have to take the top of the manifold off to expose the pipes running within...
Old Nov 19, 2010 | 04:47 AM
  #42
Antti66ht's Avatar
Antti66ht is infamous around these parts
Bought my Cayenne 04 last week, and I just wan´t to say, what a big help all of you have been already. Definately going to check the pipes and change / have them changed asap if plastic. 1kEur is small money to avoid further disaster, leaking coolants in the middle of no where. Thanks!
Antti
Old Nov 19, 2010 | 07:26 AM
  #43
snzuloz's Avatar
If it was serviced/repaired at a Porsche dealership ever they would be able to tell you if it has been performed. They use a borescope to verify the leak when it occurs so I'm guessing the pipes are not visible from above the manifold.
Old Nov 19, 2010 | 09:41 AM
  #44
TenaciousT's Avatar
Yipes....I only paid $952 from my dealer. Of course, I also paid $700 for water pump so maybe they felt bad...hah
Old Nov 19, 2010 | 09:55 AM
  #45
2muchtime's Avatar
2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute2muchtime has a reputation beyond repute
The intake manifold has to be removed to see the actual coolant pipes??
