Fuel door and Tailgate button not working
Old Nov 28, 2009 | 12:00 AM
mtimmy415's Avatar
mtimmy415 is infamous around these parts
as titled., my fuel door and tailgate button isn't working... any body has any suggestion on that?... do you think there will be a fuse for it?
Old Nov 28, 2009 | 02:47 PM
canberk's Avatar
canberk is infamous around these parts
what's going to happen if you run out of fuel?
Old Nov 28, 2009 | 09:17 PM
mtimmy415's Avatar
emergency door open
Old Nov 28, 2009 | 09:59 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Fuse
Old Nov 30, 2009 | 03:06 AM
mtimmy415's Avatar
Couldn't find it,. I opened up both left and right side console fuse boxes., found no missing nor burn out fuse... any ideas?
Old Dec 3, 2009 | 08:51 PM
roxboxxx's Avatar
roxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant future
Same issue for me. It just quit working. so I started using the emergency release. Well, the 3rd time I used it, it just pulled right out and peices went everywhere. So, now my fuel door hands open a tad. I bought the new switched from suncoast as all the fuses and relays looked fine. Unfortunatly I cannot test as the fuel door relay is laying somewhere down in the quarterpanel. Oh, and when it broke, I slammed my hand against a weld and just about needed stitches. Don't mess with it - have the stealer fix it before you break the Emergency release like I did (PS - with the rear cd player, you have to pull the entire rear wheel well interior trim pieces off - like 4 hours labor).
Old Dec 4, 2009 | 01:39 AM
mtimmy415's Avatar
That is SAD!. I think the rear control module went bad,. have you also checked if your alarm siren will sound? because I found out it dosen't work too.
Btw., you only need to remove the cd changer to get to the fuel door actulator , I read it from the cayenne workshop manual
Old Dec 4, 2009 | 10:41 AM
roxboxxx's Avatar
Alarm works thank god.
On the CDchanger: you can remove all 4 bolts, but you cannot get the units right side mounting bracket past the interior wheel-well trim. I tried for 1 hour, it's like removing a square peg from under a round hole. I did some digging and in order to get it out you have to remove the interior quarter panel. Now to remove that, you have to take out the pieces that run up the back post and across the back headliner. Then you have to pull a part of the seat, and so on, and so on. Spoke to 2 people who did it and both said it was a Biatch and 1 had rattles afterwards.
So - I will just leave the door hanging open 3 mm for now.
Old Dec 10, 2009 | 03:35 AM
mtimmy415's Avatar
update,.! I took the control switch out from the door and did a multi meter test. Found the wire has no foul..
grounded the two wires between the switch wire and ground. pop!., the door opened.., and pop the tailgate opens.
took the switches up home and did a continuity test.,!!! BOTH tailgate and fuel door switch do not CONNECT when the switch is engaged!! WEIRD.,! how can both switches fail at the same time (may be rust from rain water?)
ORDERED two new switchs from sunset motor.!! will report!
Old Dec 10, 2009 | 05:34 AM
canberk's Avatar
Porsche knows how to unleash the engineer inside us
Old Dec 11, 2009 | 02:19 AM
mtimmy415's Avatar
NO NO NO
its their STEALER that unleashed the enginneerrrr gene inside us.,.,! hahaha
97GtsMonster
Nov 17, 2015 12:38 PM
Michael_s
Sep 11, 2015 08:03 PM
turbotuner20v
Sep 11, 2015 12:02 PM
orbelo
Aug 30, 2015 12:26 PM
tkeck3
Aug 25, 2015 02:52 PM
