can someone identify this leak?
Old Dec 19, 2009 | 11:44 AM
dutchgirl6484's Avatar
dutchgirl6484 is infamous around these parts
Hi -
After having my CS 05 parked for 3 days in an inside garage in the cold of Wisconsin and driving ~25 miles home, I noticed a blueish leak from the front driver side, it seems dripping from the front of the tire flap and was sort of an icy ocean blue mix .. there was also a fairly large puddle on the garage floor a little left of the front driver wheels and about 1 foot inside of the front bumper.
The liquid has a clear blue color (pic below) to it but is very watery and has no smell to it .. what could it be? I am thinking either the washer fluid or the pentosin P/S fluid or the dreaded coolant??
I checked all fluid levels and everything is the same as before and there are no warning msgs ... also, I did fill up the P/S fluid a few weeks back (and slightly over filled above the max mark!!), it does have the PASM as well.
anyone saw something like this before??
Old Dec 19, 2009 | 12:34 PM
WayneE's Avatar
WayneE is infamous around these parts
I'd guess washer fluid, too.
Old Dec 19, 2009 | 02:30 PM
tonga3's Avatar
tonga3 is infamous around these parts
I'd say washer fluid, mine does it all winter.
Old Dec 19, 2009 | 02:34 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Most likely it is the headlamp washer jet leaking.
Old Dec 19, 2009 | 10:16 PM
nelsonmx's Avatar
nelsonmx is infamous around these parts
Mine does the same thing. Left headlight washer leaks off and on.....
Old Dec 20, 2009 | 12:47 PM
thanks, good to know its just the washer fluid ... guess I can live with it without causing any damage?
Old Dec 20, 2009 | 06:46 PM
nelsonmx's Avatar
No no damage....In fact the only damage will be to your pocket book buying washer fluid if it leaks a lot......and maybe a blue stain on your driveway (which washes off by the way)
Old Dec 21, 2009 | 10:11 PM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
I've got the same problem.
Old Jun 24, 2011 | 10:21 AM
steved76's Avatar
steved76 is infamous around these parts
Just woke up to same problem. It's the washer jet itself, right? Not the hoses/lines to the unit?
Old Jun 24, 2011 | 12:23 PM
nelsonmx's Avatar
Mine is the washer itself. The lines don't seem to leak.....
Bob
Old Jun 24, 2011 | 09:11 PM
I believe the parts catalog calls it a "washer jet carrier", as the jet itself is the small insert that does the actual spraying.
matt2ace
Nov 23, 2019 11:38 AM
TypeRx
Sep 28, 2015 08:24 PM
TOGWT
Detailing
Sep 28, 2015 08:25 AM
UrsaMinor1
Sep 26, 2015 01:23 AM
