The outcome of messing with a chipped S4.
Well, I lost. Granted my Cayenne Turbo is stock right now, besides mufflers, I got raked pretty hard by my friends GIAC chipped 2001 Audi S4. We went from around 45 and only for a few seconds as I just let off because it was a pretty hard pull he instantly had. That is his only mod, and I figured I would put up a decent fight, but it really wasnt even that close. So, with all the mods I am planning, (ECU, bypass pipes, Diverter valves, BMC, and maybe the sport option intercoolers if I can get them cheap enough, you think I could hang?
Harris
Harris
Re: The outcome of messing with a chipped S4.
Harris
Harris
ben, no I was in M with PSM off in 2nd gear at around 45-48MPH. I actually got the hit a little.
But yes, I figured the weight was a major issue. I had no problems running the car when it was stock, especially in my black CT, in which I would pull relatively hard, but that chip really made a big difference!
I am extremely suprised at how affective the GIAC ecu is for an S4
A GIAC X chip will bump the car to about 310hp - it really is a totally different car after chipping. I'm still surprised your friend was able to pull that well - although I suppose there is a huge weight difference. It's possible he was running 100 octane too - the compression ratio in the S4 is rather high and we see large gains from race gas (on a car like mine, we'll see a 100hp difference at the wheels between pump and 100).
GIAC X is known for blowing the K03 turbos quite often though, so tell your friend to take it easy
s6spd
Oct 6, 2015 08:20 PM
alpha motoring
Oct 2, 2015 12:04 PM
