Anyone find a great aftermarket battery for Cayenne S
Subscribe
May 12, 2010 | 08:45 AM
Quote: I bought mine from Walmart. It was a little smaller, but it working great.
Which battery you bought from Walmart?
Reply
May 12, 2010 | 10:10 AM
I will take a look at my receipt when I get home. Walmart simply rebadges a Johnson Controls battery. So does Sears and Autozone. There is a great thread 996 thread on RennTech. So whatever the Autozone size is, that is the Everstart one as well, but cheaper. Comes with a vent kit too.
Reply
Sep 8, 2014 | 11:38 AM
https://www.6speedonline.com/forums/...ml#post4191185
Reply
Dec 29, 2014 | 05:18 PM
FYI do not ever use this battery (MTP-49/H8), even it is straight from the Interstate web site. This Interestate battery only got 720cca and is known to have problem starting your Cayenne especially in cold weather.
The correct one to use is Interstate MT5-49/H8, it is a AGM battery with 900 cca and 1000ca.
Quote: Interstate Battery aftermarket battery for 2006 Cayenne V8;
http://www.interstatebatteries.com/c...nths+-+720+CCA
Product ID: MTP-H8
Short Description: Interstate - 85 Months - 720 CCA
Amps: 900
Cranking Amps: 900
Cold Cranking Amps: 720
Voltage: 12
Termination: A
Pro-rata Warranty: 85
Weight: 53.6
Width: 6.89
Length: 13.94
Height: 7.48
Reply
Dec 29, 2014 | 10:54 PM
If money isn't a issue look up Total Power racing batteries. This is high end stuff you can buy and it military grade. They are used on the stealth bombers and so on. Might be o we kill for you?
Reply
Dec 30, 2014 | 05:49 PM
I went with the Interstate and it's the correct original size.
Reply
Jan 6, 2015 | 10:31 AM
Quote: FYI do not ever use this battery (MTP-49/H8), even it is straight from the Interstate web site. This Interestate battery only got 720cca and is known to have problem starting your Cayenne especially in cold weather.
Actually, if you're not hung up on buying an AGM battery (with a lesser warranty), the correct Interstate battery is the MTP-95R/H9. It has CCA of 850, RC of 180 (versus only 160 for the MT5-49/H8), CA of 1000, and AH of 110 (versus only 95 for the MT5-49/H8).
As a refresher, CCA (cold cranking amps) is the cranking power for 30 seconds at 0 degrees F., RC (reserve capacity) is a battery's minutes of 25 amp output at 80 degrees F., CA (cranking amps) is the cranking power for 30 seconds at 32 degrees F., and Ah (Ampere Hour) is an automotive battery's electrical 20-hour storage capacity at 77 degrees F.
The MTP-95R/H9 is nearly two inches longer than the smaller AGM battery, and obviously both its RC and Ah rating well exceed the smaller AGM battery. I'd say unless you live in a climate where 0 degrees outdoors is the norm, and your Pig is parked outdoors, the 50 additional CCA of the AGM battery are easily more than offset by the much greater electrical capacity of the larger battery.
When I was at my local Interstate store, I looked at both, considered their respective specs, and choosing the higher capacity battery was an easy choice. Fits like a glove in the battery compartment under the seat, too. As always, YMMV.
Reply
Jan 7, 2015 | 01:41 PM
H9 from Interstate - what we use and recommend here at the shop. Zero problems, the price is right and the warranty it carries - you really can't beat it.
Don't get me started on factory Porsche batteries....
Reply
Jun 22, 2015 | 06:19 PM
Edit update. The H8 is dangerously too short after attempting to install it. One of the two brackets won't hold it in place and it could slide forward or back a couple inches.
Ordered the H9 for install tomorrow.
Thank you for the information.
I am going with the Interstate MT5-49/H8 from the local Interstate store, $10 extra charge do to the underseat placement and a 10% coupon from their site good until end of July = $180
I didnt go with the H9 - it costs a bit more, we are not in a cold climate and typically special order.
Reply
Jun 28, 2015 | 02:05 PM
Deka GOLD 950 CCA = $135
Fits under the Cayenne driver's seat like a glove. Made in USA:
Reply
Jun 28, 2015 | 03:32 PM
Got this from Napa fit like stock
Reply
Jun 28, 2015 | 05:12 PM
That is made in USA by East Penn Mfg(Deka/Odyssey/NAPA).
Reply
Jul 11, 2015 | 10:39 AM
I have the new Bosch AGM battery. Blue top. Works like a champ. 4 year full replacement and it has no cells or water. Charges really fast and I have tons of Amps, video, GPS.....It's about an inch smaller in length, but my hold downs still hold it well. Just rotate the front bracket a little.
Reply
Jul 11, 2015 | 10:42 AM
http://www.pepboys.com/product/detai...04.5L%2520DOHC
On sale now. lol
Reply
Apr 27, 2019 | 11:28 PM
A lot of the battery threads are quite old, partly because the Cayenne goes back a few years now. There is a lot of misinformation, with people saying smaller battery is OK, etc. I learned, after going through a lot of trouble, that a Gen1 & 2 Cayenne definitively needs an Interstate H9. The exact part number is Interstate MTP-95R/H9. Go to an Interstate dealer and get this battery. This is the correct German made replacement that is identical to OEM. It fills up the battery compartment under the seat, as it was designed to, with no room to spare.
H9 in Cayenne
Reply
