Gear display goes blank on dash
Old Apr 21, 2010 | 10:54 AM
xTapouTx's Avatar
xTapouTx is infamous around these parts
Anyone ever had this issue?
After a few min of driving, the car will shift fine through the gears and show that is in 2 then 3 then 4...etc but then after a few min it shows nothing. Actually it shows all the symbols on the right higlighted. Like Park, Reverse, Nuteral...etc.
I'll post a pic so you can get a visual.
Old Apr 23, 2010 | 08:13 PM
canberk's Avatar
canberk is infamous around these parts
do you have any problems with transmission?
Old Apr 24, 2010 | 05:29 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
I think that means limp mode is activated for the transmission... but this would be a very good time to scan it and get the codes. That should show what is happening.
Old Apr 26, 2010 | 06:20 AM
Botox's Avatar
Botox has a spectacular aura aboutBotox has a spectacular aura aboutBotox has a spectacular aura about
I have had the compass module sometimes not show up on the Left side of my center display like yours. Shouldn't you have a full time compass on the Left? Mine comes and goes, the only annoying electrical gremlin on my 09 Turbo S.
Old Apr 26, 2010 | 07:46 AM
Pepper's Avatar
Pepper is infamous around these parts
I lost all my display, it gradually came back and found out it was...
the sun! Yes, I live in Florida, and the car was sitting a few hours at the right angle on the dash display and when I tapped the glass thinking it may be a loose wire I burned the hell out of my fingers touching it. I tinted my front windows and use a screen on my windshield when parked now. I will never forget a friend of my frying an egg on the hood of his Lexus...the sun is an electronics killer.
Old Apr 26, 2010 | 11:38 AM
xTapouTx's Avatar
Nope no problems....although i can't go into tiptonic with gear shifter anymore. The steering wheel controls still work just fine.
Old Apr 26, 2010 | 09:15 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
My guess would be the black "accordion" plastic guide inside the shifter, it can get damaged and bunched up and cause this display. It is available separately, and isn't a bad DIY.
Old Apr 26, 2010 | 09:30 PM
xTapouTx's Avatar
You're absolutely right!! That plastic/rubber sheath split about a week ago and that's when they both started happening.
Is there a DIY guide on that or could you shoot me a quick list of steps for this?
What is that part called?
Old Apr 27, 2010 | 07:01 AM
The part is called a shade, and the number is 955-552-265-00. It is a lot easier if you get the entire shift gate but it will be more expensive, it is number 955-552-261-01-62w for the satin aluminum finish ones. I don't have a DIY for this, but it isn't bad, take the console cover off, shift ****, then the rest of the pieces have tabs that you lever over and everything comes apart nicely.
Old Apr 29, 2010 | 11:17 AM
xTapouTx's Avatar
Now that was extremely helpful!! Thanks man!
Old Apr 29, 2010 | 05:03 PM
canberk's Avatar
i love how this forum solves your problems..
Old Apr 29, 2010 | 07:29 PM
No problem, hopefully that gets you going in the right direction
Old May 25, 2011 | 11:31 AM
jetmax's Avatar
jetmax is infamous around these parts
Can anyone give me more info or photos of how to take the console out to get to the Sun Shade?
955.552.265.00
John
Old May 26, 2011 | 08:43 AM
khairo82's Avatar
khairo82 is infamous around these parts
mine on my cs 05 does the same thing , i cant c anything during the day sometimes i do its driving me crazy ... i dont know if i have to change the whole thing..
any suggestions?
Old Jun 2, 2011 | 09:14 AM
xTapouTx's Avatar
I took some pics a while ago when I did this, I'll see if I still have them. As porschespeeddemon said it is easier just buying the whole thing. This isn't a bad job at all guys, I have faith that you can do it. I'll be back with pics.
