Anyone tried this eBay backup camera?
Old Jun 5, 2010 | 11:59 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Question Anyone tried this eBay backup camera?
Seems like a cheap solutionfor a backup cam for these.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
This is for an 04 CTT
Old Jun 5, 2010 | 12:49 PM
canberk's Avatar
canberk is infamous around these parts
i dont think its compatible with pcm display.
Old Jun 5, 2010 | 01:03 PM
Cole's Avatar
Why? The listing claims it's made for it.
People used these generic cameras with the Jeep nav all the time with good results. It is also produced by Harmon Becker, the same manufacturer of the porsche unit.
Old Jun 5, 2010 | 06:45 PM
FAUEE's Avatar
FAUEE is a jewel in the roughFAUEE is a jewel in the roughFAUEE is a jewel in the roughFAUEE is a jewel in the rough
I've got one of the generic cams on my car (a different one though). Refresh is OK, Not much color, but it works.
Not a lot of factory radios have video RCA inputs (or outputs).
Old Jun 5, 2010 | 09:20 PM
Cole's Avatar
So did yours plugmin just like the oje in the listing?
Old Jun 5, 2010 | 09:53 PM
FAUEE's Avatar
Yeah, its got a weird little plug after about a foot of wire and then the RCA end. That plugs into a little thing and has these tiny tiny wires for your power and ground.
But I've got an aftermarket radio that has an RCA input. Most of the cameras on ebay are all of the same design thrown into various packages. Mine was one of the night vision IR LED ones, I disassembled it for my purposes.
Old Jun 7, 2010 | 07:37 AM
tyorll's Avatar
tyorll is infamous around these parts
Thumbs up
I've used a similar camera off ebay on my head unit, however it is an aftermarket Eclipse AVN726EA. My camera had the same wires as the ebay cam you linked and I just chopped off the RCA connector and manually wired it to the back of the head unit using custom connections (for my unit this was the little metal plugs that I pulled out of some spare computer parts - to be exact it was the little metal clips contained within the plastic plugs that connect a CD/DVD audio to motherboard connector in a PC). I doubt the porsche PCM would be very much different. Just a matter of working out which pins on the back of the unit correspond to the +ve/-ve, power, ground which you could get from a wiring diagram that someone on these forums should have.
The hard part is actually running the wires from the head unit to the camera at the rear of the car. I had to run both power and video cables, as well as a reverse signal light wire so that the camera would automatically switch on when reverse gear was selected.
Took some time - total circa 6hours to install, but it works flawlessly now, and my cam has night vision to boot which is a neat function.
Old Jul 27, 2010 | 08:28 PM
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
I have been looking at these cameras on Ebay also and I am highly interested in knowing if there is a way to correctly mate it to the factory nav display.
Old Aug 10, 2010 | 07:52 AM
pearlwhites's Avatar
pearlwhites is infamous around these parts
I'm definately looking into this as well. Keep us posted if you give it a try!
Old Aug 16, 2010 | 09:26 AM
kel789's Avatar
kel789 is infamous around these parts
i stumbled onto this thread. i also would like to use a cheapo less than $20 ebay camera. i see many video clips like Crutchfield on using the tail light circuit to power the camera. why is this not a good option? is it the tail light has too much current going to the camera?
Old Aug 16, 2010 | 12:53 PM
pcst's Avatar
pcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the roughpcst is a jewel in the rough
I'm also interested in this thread, I have the parking sensors, but I think the backup camera helps much better than those sensors.
Old Aug 16, 2010 | 02:49 PM
Cole's Avatar
Especially when trying to line up the race car trailer
Perkman87
Nov 19, 2015 05:31 PM
navtool.com
Lexus Vendor Classifieds
Oct 1, 2015 11:14 AM
navtool.com
NY Tri State
Oct 1, 2015 11:13 AM
navtool.com
navtool.com
Oct 1, 2015 11:10 AM
