Starting Problems - 08' Cayenne Turbo
Old Jul 13, 2010 | 06:01 PM
spinny02's Avatar
spinny02 is infamous around these parts
Cool Starting Problems - 08' Cayenne Turbo
Hi All,
I just picked up an 08' Cayenne Turbo on Wed. My wife says it is taking 5-8 sec to start.
The car is still under warrenty, and just had its 40,000 porsche service.
What could it be?
Batt?
Starter?
Plugs?
Old Jul 13, 2010 | 06:36 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Well if you're getting crank rule out the Battery.
If you can hear it cranking over rule out the starter.
Plugs fouling? Not likely if the Cayenne was just serviced, but I would not rule out the "COIL-PACKS", these items start fouling out around 40-50K especially on Turbo models. This will be covered under your warranty.
-Eli
Old Jul 13, 2010 | 07:09 PM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
8 seconds after you just flick the key to the start position and let go?
could be a weak relay in your dash, you can hear it clickin. take it in let
a dealer think on it.
Old Jul 14, 2010 | 12:04 AM
spinny02's Avatar
Thanks Guys. I am out of town but i am making an appointment to have her take the car in in the AM.
Old Jul 14, 2010 | 06:14 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
My guess is high pressure fuel pump or related component(s).
Old Jul 15, 2010 | 01:09 PM
StockToPerforma's Avatar
StockToPerforma is infamous around these parts
Took the words right outa my mouth - though the coilpacks could be suspect as well.
Old Jul 15, 2010 | 10:31 PM
Possible, though have not heard of any coilpacks fail on 08+ Cayennes yet, and vehicle would still start on cars that had faulty coil packs, just would idle very rough and hesitate on accelration.
Old Jul 16, 2010 | 08:12 PM
spinny02's Avatar
ALL,
Thanks for your input. It was the fuel filter.
- JS
Old Jul 18, 2010 | 01:03 PM
cuemaster's Avatar
easy fix good to know.
Old Jun 30, 2012 | 07:51 PM
Jimmy Low's Avatar
Jimmy Low is infamous around these parts
Cayenne 2008 turbo starting issue
Hi am new here. Just gotten a CT for 6months n now experiencing help needed.
I have cranking issue while starting the car. I have changed a new battery n it helps for about a month or so n now when u crank, it hesitate but once u hear it crank, it will start immediately.
Can anyone help share if they have similar issue n what is the solution? Tks
Old Nov 23, 2013 | 10:51 AM
lesac1119's Avatar
lesac1119 is infamous around these parts
Hi all. My 08 Cayenne S has this problem nearly every time....It always starts the second time (sometimes takes a couple more) but I fear it may strand me.
Has anyone had this problem fixed? If so, what was the problem and how much was it? I have an amazing independent mechanic, but he said this kind of problem can only be fixed by the dealer b/c they have proprietary software to diagnose the problem. Help??
Old Nov 23, 2013 | 06:12 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
I haven't had the problem but, it sounds pretty simple. Get thee to the dealership.
socialpro
Cayenne 958
May 18, 2016 09:58 AM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
