Those with Xenon Fogs please read....
Old Aug 17, 2010 | 08:28 AM
RojoGTS's Avatar
RojoGTS is infamous around these parts
Originally Posted by FastHackem
Are you worried about the heat from using resistors or heat with a 55w kit. I am currently running a 55w kit in my WRX headlights for the high beam and the low beam and havent noticed any real difference in the heat levels when I was running 35w kits. Now resistors on the other hand get really freakin hot. You have to be careful about where they are located because they do get hot enough to melt plastic and skin for that matter. As for a kit that will not run a code, i think the best bet is a 55w kit, which I haven't tried, just because of the reason the code is being brought up in the first place. The system is designed to detect 55w of draw per side and when the system detects anything less, like your 35w hid kit, it sees an error and throws the code. Maybe a canbus type hid kit will work. They are a little more expensive but they claim to work with canbus electrical systems with zero errors. Not too big of a selection here in the US either.
I was worried about the heat out put in a small fog light, I have seen melted housings cracked lenses etc...
Any reson why the code only happens when a turn the fogs off ?
Old Aug 17, 2010 | 08:24 PM
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
Here's a pic of the kit I was using along with the resistor next to my finger. Never had a problem with any errors. Took it out after I sold my last turbo and will probably re use it on another car or put it in the fs section. Before adding the resistor I didn't have any errors but my fogs would flicker and not ignite some times. Hope this helps a bit.
Old Aug 17, 2010 | 08:28 PM
Mamut79's Avatar
Mamut79 is infamous around these parts
people with problems, what ballast are you using? I am using ballast as per photo above ( big fat) without any canceling error boxes, and everything works perfectly ( o6 cayenne fog 3000k) . I noticed the credit card size ballasts are the culprits. i had problem with them on my r56 mini ( both head and fog) 06 c230 (fog), the minute i changed them to fat ballasts everything was corrected.
Old Aug 18, 2010 | 02:26 PM
RojoGTS's Avatar
So the larger ballast have worked, Who here has a 35w kit that works ? name of the comany ?
Old Aug 18, 2010 | 02:38 PM
C4SxM5's Avatar
I think the pic I posted has all the info you just asked for
Old Aug 18, 2010 | 02:55 PM
RojoGTS's Avatar
So these came out of a cayenne turbo?
Old Aug 18, 2010 | 02:58 PM
C4SxM5's Avatar
Sorry 2007 997turbo
Old Aug 18, 2010 | 03:47 PM
RojoGTS's Avatar
Yea it seams these kit can differ from car to car as well with the code I had the same problem in my Benz... I went trought 3 kits to get the right one.
Sorry 2007 997turbo
Old Aug 18, 2010 | 06:24 PM
Mamut79's Avatar
im using DDm kit, but with FAT BALLAST, not the credit card skinny one, works perfect for me. Tomorrow my other kit arrives for headlamps, ill keep you guys updated about that install.
Old Aug 19, 2010 | 01:53 PM
Mamut79's Avatar
Ok, another kit installed onto my car. This time headlamp received the upgrade. DDm kit h7 6000k. Again used a fat ballast, and again it works flawlessly .
Old Nov 21, 2010 | 03:45 PM
FastHackem's Avatar
FastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud ofFastHackem has much to be proud of
Smile
Just to clarify for some people, that is not a resistor in the picture. It is a capacitor most likely rated at 25V 10000uF.
Old Mar 26, 2011 | 02:54 AM
a17322a's Avatar
a17322a is infamous around these parts
Hi Mamut79 did you get the 55w h7 or the 35w h7 kit? I see that the only thick ballast is the apexcore Raptor one is that one you that you got?
http://www.ddmtuning.com/Products/Ap...Raptor-HID-Kit
thanks
Old Mar 26, 2011 | 05:53 AM
Mamut79's Avatar
35w Raptor Kit...
Old Mar 28, 2011 | 01:15 AM
mitcho168's Avatar
mitcho168 is infamous around these parts
the caps work i got a set left if anyone is interested.
and i got a fog light kit left also if anyone is interested. = D brand new in box
Old Mar 28, 2011 | 04:45 AM
FastHackem's Avatar
Post in the classified sections if you want to sell something.
