Water coolant issues? or just sensitive sensors?
Old Dec 30, 2010 | 04:57 AM
Jimmi's Avatar
Jimmi is infamous around these parts
Hi All
The other day my water coolant level warning came up so I went straight to the garage to top it up with water, but found that it only needed half a bottle? is that normal due to the sensors being very sensitive? I hope its not some water coolant issue, mind you since i topped it up about 4 days ago the warning hasnt come up?
Old Dec 30, 2010 | 08:13 AM
snzuloz's Avatar
snzuloz is infamous around these parts
Originally Posted by Jimmi
Hi All
What are you driving? Warranty?
I would keep a very close eye on it (look where you park for any signs of coolant), if your coolant pipes are still plastic (original) it would be very cost effective to be proactive rather than wait for it to develop and potentially cost some big money to replace trans input seal, starter etc, let alone leave you stranded.
Old Dec 30, 2010 | 08:56 AM
cordsig79's Avatar
cordsig79 has a spectacular aura aboutcordsig79 has a spectacular aura about
You need to be using good coolant and only Water in emergency situations.
The coolant does burn off over time, and typically a warning will fire off sproradically in hard turns, so just top it off.
Old Dec 30, 2010 | 02:48 PM
seankrider's Avatar
seankrider is infamous around these parts
Okay - so is that true?
I called 4 nearby P-dealers back in October on this exact question, and every one of them said straight tap water would work fine, even for long term use (Northern California).
Not distilled, not the P-coolant.
Old Dec 30, 2010 | 03:12 PM
cordsig79's Avatar
deposits become a big issue in the future.....just sold a jeep I bought at the same time as the Cayenne. Radiator had Stalagtites in it basically from not enough coolant to stop deposit formations. Both have/had 100k, cayenne just has wear on leather seats and Jeep fell completely apart.
Its your car but I would stick with pure coolant for longevity.
87 octane works too but it doesnt burn hot enough and you'll feel real sluggish.
Old Dec 30, 2010 | 03:16 PM
cordsig79's Avatar
oh and due to the tap water, I had to replace the clutch fan, thermostat, hoses, and was probably close to having a head gasket blow, along with flushing the radiator every 6 months.
I know coolant can be corrosive and maybe it was just a chrysler build issue but, Id rather be pure on this car.
I maybe eating my words in the future and posting a thread on how to put a crate V8 engine and match it to the current tranny!!
Old Dec 30, 2010 | 05:10 PM
seankrider's Avatar
So those were my thoughts exactly... until 4 out of 4 service guys at the dealers said don't worry about it.
I think I'm running 50-50 since an October when I put in aluminum pipes. Dealer sold me 2 gallons to refill it, saying that was the capacity. Of course it holds 4, and I forgot to check before I drove over there.
Should I flush it out and refill with coolant only?
Old Dec 30, 2010 | 08:08 PM
snzuloz's Avatar
Keep your coolant at the 50-50 mix, it will be fine-this is the recommended mix for most coolants on the market (cooling would be affected-thats what the water is for). The only way that there is any corrosion in the system is from a breakdown of the coolant over time (poor maintenance or not using long life antifreeze), combustion leaks-minor obviously. Most corrosion occurs for those that skimp on the antifreeze and don't have enough of the additives from the coolant to protect such items as rads, water pumps etc. Distilled water is recommended as well, but I have had no issues with tap water over my years.
Old Dec 31, 2010 | 06:14 AM
cordsig79's Avatar
Thats what is funny about the Jeep, I figured whats good for the goose is good for the gander.....meaning I put the P dealers recommended "long life" coolant in the Jeep too. The Jeep guys blamed me for not using water for the corrosion, then blamed the possible tap water usage when it was intially purchased on the buildup?
Ah....whats real, whats not? The P held up so far anyway with the dealer coolant.
Old Jan 1, 2011 | 08:42 AM
Jimmi's Avatar
water coolant!
thanks guys, i double checked and one of the guys at the dealers recommended topping it up if the sensors tell me to.
Old Jan 2, 2011 | 10:21 AM
Jeff SD's Avatar
Jeff SD is a jewel in the roughJeff SD is a jewel in the roughJeff SD is a jewel in the rough
Hi All
I would still bring it in for a pressure test.
viprklr
May 23, 2018 11:33 AM
LiquidElephant
Aug 27, 2015 06:17 PM
PelicanParts.com
Aug 26, 2015 04:25 PM
PelicanParts.com
Aug 26, 2015 04:24 PM
