oil level at 1/2..
Old Jan 28, 2011 | 10:02 PM
Markenstein3D's Avatar
Markenstein3D is infamous around these parts
oil level at 1/2..
so after almost 2k miles, the oil level is at 1/2.. wanting to top it off..
how much oil do i need to use?
newbie in this thing.. i'm so used to having oil changes at 3k miles for jap cars.. can't afford that for the cayenne as it's way expensive..
also, what type of oil do i use? i misplaced the manual.. can't find it
do i just open the oil cap and pour it in?
thanks in advance..
Old Jan 28, 2011 | 10:59 PM
pakundo's Avatar
pakundo is infamous around these parts
Old Jan 29, 2011 | 11:02 AM
i'm not sure if they used:
Mobil 1 0W-40 or 5W-40..
are these the same? can they be mixed (mixed = if they used 0W-40 and top with 5W-40/or vice-versa - is this ok? or would it cause problems?)
Old Jan 30, 2011 | 12:56 AM
spinny02's Avatar
spinny02 is infamous around these parts
Mark3D,
Dont mix it. 0W-40 is what you need.
I bought it at O'Reilly Auto Parts abt $50 for the case of 6 qts. (i have used 4 qts in the last 4 months)
Old Jan 30, 2011 | 08:31 AM
pakundo's Avatar
Both a 5W-40 and 0W-40 will provide the same level of protection at high temperatures, especially if you are using a product like Mobil 1. As far as the 0W versus the 5W, this should not make a difference for you other than at start-up. The 0W would provide you a faster start-up at low temperature but you are unlikely to see the differences in your climate. Either grade is fine for you and unless you are having any issues, we recommend you stay with Mobil 1 0W-40 as it is specifically designed for your type of vehicle
Old Jan 30, 2011 | 08:35 AM
as much as i want to top it off this weekend.. might as well call the indie shop tomorrow if they have "records" of what they used.. other than that, i may just go with an oil-flush :-( just to be sure..
thanks guys for the response
Old Jan 30, 2011 | 08:43 AM
keeperofbeasts's Avatar
keeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond reputekeeperofbeasts has a reputation beyond repute
Thumbs up
thanks in advance..
you can open the cap and pour it but if its at 1/2 I dont think you need to worry about for another 2 K miles or so....no?
ECS Tuning - VW
Sep 8, 2015 01:34 PM
DLF
Cayenne Turbo
Sep 3, 2015 01:36 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
