Need Help With Amp On 2005 Cayenne
Old Apr 3, 2011 | 02:55 PM
m34door's Avatar
m34door is infamous around these parts
Guys one of my Cayennes particularly the 2005 4s has given me the first headache after 6 years. The factory amplifier has given up and would like your recommendations or suggestions on how I resolve such an issue. Should I go aftermarket, or buy new from dealer.
Old Apr 3, 2011 | 03:22 PM
dave-t's Avatar
dave-t is infamous around these parts
I believe you still have to have a factory amp in your truck regardless going aftermarket or not. You need the factory amp to run your whole car. Aftermarket amps are just for a stereo. When putting in a aftermarket stereo I believe you still have to tap into the factory amp. Even if you are replacing the headunit. If you use a OEM interface( JL CleanSweep or AudioControls) with an aftermarket system you definitely have to keep you factory amp because thats what I have
dave-t
Old Apr 3, 2011 | 08:15 PM
m34door's Avatar
Well My intension is to keep the factory stereo. The issue at hand is the fact that the OEM amp is not working. Can I replace it(factory Amp) with and aftermarket to enable the radio to work?
Old Apr 4, 2011 | 06:26 AM
Shawn Stanford's Avatar
Shawn Stanford is infamous around these parts
I recently replaced the head unit on my non-BOSE '05 with a JVC head unit. I didn't replace the amp, but based on what was found when the Becker unit was pulled, the amp on non-BOSE systems is not a MOST-compatible amp; so you should be able to replace it with any standard aftermarket amp with no problems.
Old Apr 4, 2011 | 10:53 AM
m34door's Avatar
Any recommendations?
Old Apr 4, 2011 | 03:07 PM
Sorry, my brother is the expert (he was a professional installer for many years). And, as I said, I only replaced the head unit (with a JVC KD-HDR50).
Rampino
Cayenne
11
Jun 27, 2017 06:27 AM
pshep138
Oct 6, 2015 11:58 AM
cporterfield
Cayenne 955/957
Sep 3, 2015 06:54 PM
the997dude
Sep 2, 2015 08:51 PM
