Cayenne S Temp Sensors... location anyone?
Old May 19, 2011 | 06:53 AM
lbredefe's Avatar
lbredefe is infamous around these parts
Angry Cayenne S Temp Sensors... location anyone?
The other night I pulled my Cayenne into the garage to swap the bad driveshaft in it. The car had set for 5 days under heavy rain somedays. I shut the vehicle off and the cooling fans kept running. over 7 minutes before I disconnected the negative on the battery. Upon doing some research I found that people are having issues at about my mileage range (I am at 72868) with the coolant temp sensors. I understand there are two of them on the V8 models? The part is cheap, and I want to DIY this and get it over with.
1) where can I find the radiator fan temp sensor / switch?
2) upon reconnecting the batt cable and bringing it back out into the driveway, i noticed the PSM fault light is on... is this normal and will it go off after restarting again?
UPDATE
upon acquiring an all-data subscription I have noticed there is a coolant temp sensor for the computer and a radiator fan temp sensor / switch. given the guage is displaying the correct temp, am I to assume the coolant temp sensor is fine and it is the radiator fan temp sensor / switch?
best,
Lance
Last edited by lbredefe; May 20, 2011 at 07:11 AM. Reason: updating new info i discovered
Old Oct 22, 2024 | 02:54 PM
Sustaina_Shaeyman's Avatar
Sustaina_Shaeyman
Pulling ancient BUMP on this?
UPDATE
best,
Lance
Hello Lance, and all here.
I have the same symptoms and wanna know the awesome results you had????!?!
Fans run great on hot engine temp, gauge reads accurate range, iCarSoft AcR PRO+ reads 40-60c warming up (ok) and all fuse boxes get power.
​​​​​​Putting HVAC settings on (low low) and blower high gets no AC compressor engagement, no cooling fans. Power to compressor. Bought 2 new fans and controllers, but couldn't get them to activate testing with VCDS or turn with hot temps, while original fanset was able to- so originals stayed.
Wanting to piggyback my VCDS cable with (Porsche mod pin 3, 7, 15) y-cable, and rescan. iCarSoft will read engine and transmission modules but says no communication from controller for HVAC.
I just can't believe this will be due to an inside air temp sensor combo, door flap combo or similar - as there seems to be no noticeable flappy issues or codes pulled for these systems ever....
​​​​​​Aloha from sweatsville Hawaii
61mga
Jun 23, 2022 11:46 AM
LouDA
Jun 9, 2020 10:39 PM
mike2016
Jan 25, 2015 05:44 PM
joebee
Jul 21, 2014 06:06 PM
jc_333
Bentley
11
Jul 17, 2014 09:46 PM
