Hello....Just got 08 Cayenne Turbo
Hello everyone, I've lurked around here and decided it's time to join. Picked up this Cayenne a couple of weeks ago. Hope to keep it for awhile.
So far I did quick detail, clear front corners, lowering links, lowering module to lock suspension, detailed the brake rotor hats (black), rear wiper delete, secondary bypass exhaust, set of 22" EvoKlass wheels from Wheels Boutique. Other parts from Greenmotorsport. Awesome service.....
Shipped and on the way EVOM air intake and IPD Intake Plenum.
1/4 mile track runs:
Totally stock, did only one run, 13.7 @107
Best ET so far 13.3 @ 105 with bypass pipes and 22's
Here's some pics of my rig:
Thanks, all. As for the rear wiper, I've always had my rides smoothed, shaved etc.....Now in my older age I've calmed down some. The rear wiper is just an eye sore for me and it left the glass etched some in it's relaxed position. Polishing it took most of it out. Just a personal thing. Thank goodness the previous owner didn't use it or use it much so it doesn't have the half moon etched effects. I'll never use the rear wiper and it was so easy to just remove and make a filler for the gap that is left.
Was thinking of removing the badge on the hatch too but I think it will be faded in and would need a serious polishing. For now it will have to stay. Cleaning between all those letters was a real PITA.
Once I get the more important mods out of the way I will use a own pneumatic air setup to control the suspension. I don't like having it electronically controlled. I'm glad the factory air suspension is on point or I would have had to do my own custom setup.
Looks good. Doesn't look too different than my 08 CTT.
Glad to see that you are running it hard as well.
Even though I have a softronics ECU, you will definitely notice a big "personality change" when going with your EVOMS it tune.
I would suggest either the BMC air filter or the Agency Power Cold Air Intake, as well as upgraded diverter valves to hold the higher boost levels.
I can tell you that the low-end on my truck went from "meh" (see my inital post on this board about being disappointed during a test drive) to down right "scary".
There has been moments when you just hold on for the ride after I did all the mods above - both on the low-end and top-end.
High 12's are easily attainable once all those mods are combined.
Now that I think about it, I think I need to break out my G-Tech Pro from storage.
ECU Flash first... We do it via the OBDII port as there is no need to pull the ECU.
Do the BMC filter, and then you are happy is a pig in...
Cayenne parts here - http://www.vividracing.com/catalog/P...8-8-38-38.html
I also have a CTT same year blk/blk. My favorite option is pdcc, coming from a 05 ctt that did not have it you can really tell the difference. Not to mention DFI.
Doesn't the Gen 2 CTT look much better on exterior than the new Gen CTT? I am sorry but just having a hard time distinguishing between the 2011 turbo and all the other models that look pretty much just like it with exception of slightly larger grills.
I am going to keep mine till the CPO runs out which is 2 more years or up to 100k. I have 54k ish now and loving it. Congrats and enjoy in good health.
I've had the IPD on for a bit. Seems to drive just fine. No real seat of the pants feeling of more power. Haven't gone to the track with just that installed. I've been waiting for the EVOM air intake and it should be here Monday. I'll install that and then off to the track. I also should be installing the rear section of SuperSprint race exhaust.
I think alot of people get caught-up in "newer must be better", which is not always the case.
This also falls in line with my surprise that more members do not promote the direct fuel injection or Variable Valve Timing upgrades that came in 08. As soon as I saw those two upgrades, I know I could not consider any Cayenne without it.
