Mobridge (BT+iPod unit) issues with iPhone
If I'm using an iPhone (with BT enabled and synced) hooked up to the Mobridge iPod connector for audio, with the head unit still ON playing from the iPhone (hooked up to dock connector), if I turn off the engine, remove the key, re-insert the key and turn the engine back ON the music restarts from another track (first alpha track) and plays for several seconds then goes mute (track timer keeps counting up).
This does not happen if the BT is disabled on the iPhone (or BT phone not synced with Mobrdige) or if I use a standalone iPod without BT phone enabled to the Mobridge. Or, this is not an issue if I remove the iPhone after turning OFF the vehicle and re-inserting immediately before/after restarting the engine.
Anyone ever observed this?
