bad feul pumps
Old Sep 20, 2011 | 09:40 PM
khairo82's Avatar
khairo82 is infamous around these parts
bad feul pumps
if you have bad feul pumps , does it affect the cars performance??
i feel like my car is heavy now although i changed the coils and plugs..
Old Sep 21, 2011 | 11:06 AM
ohboy's Avatar
ohboy is infamous around these parts
If your fuel pump is bad, the vehicle would not run at all.
Old Sep 21, 2011 | 01:34 PM
Dennis C's Avatar
Actually that's not entirely true. When a fuel pump is beginning to fail, it won't deliver consistent fuel pressure, causing the vehicle to sputter on occasion. When this does happen, it's a sign of an impending failure of the pump.
Old Sep 21, 2011 | 09:32 PM
khairo82's Avatar
thank u guys...
dennis c , ya the car sometimes it does sputter most of the time when im driving on low speeds...do u know where can i buy originl porsche ones online, here in jordan there expesive at the dealer ship, around 800$$ with no labor..
i found them at vertexauto.com not sure if originl though..
Old Sep 22, 2011 | 07:21 AM
ohboy's Avatar
I'm sorry, I should've clarified myself a little better. Dennis you are absolutely right. Thank you.
Old Sep 22, 2011 | 07:27 AM
Dennis C's Avatar
I'm not sure on a good source. I had mine replaced by my local mechanic.
I'm my case, only one of the two fuel pumps was failing.
Old Sep 22, 2011 | 07:36 AM
ohboy's Avatar
I just replaced my fuel pump on the left side a few weeks ago. The left side pump is the main pump and the right side pump is the auxilary pump. It is very commonn that the left side pump fails.
Old Sep 22, 2011 | 08:52 AM
khairo82's Avatar
my cs sputter sometimes now , feels like the car is heavy , i did upgrade my coils and plugs ,, but still same issue so i think its the pumps...
did u notice ny difference when u changed yours ohboy??
Old Sep 22, 2011 | 10:05 AM
ohboy's Avatar
Mine was sputtering for a good 100 miles and then I stopped at a rest stop. when I came out, the vehicle would start for 5 seconds then quit every time I started the vehicle so I towed it to my shop and tested the main fuel pump to find out there was no pressure. I put direct power to the pump and the pump would not run so after I replaced it, the vehicle ran beautiful! I would begin with replacing the left side pump first.
adnanm3
Nov 22, 2023 02:43 AM
Rguy
Apr 12, 2020 11:11 PM
pwdrhound
Sep 13, 2016 10:44 AM
Wheeler
Sep 22, 2015 08:02 PM
MrMiggy
Sep 14, 2015 02:18 PM
