heads up display for cars
Old Mar 25, 2012 | 09:21 AM
ciaka's Avatar
as anyone thought to, or actually installed some think like this on their ctt? I am curious but do not want to put something in that will look crappy, and am on the fence on this ( like the ctt gauges).
Hooks up to the odb2 port for info.
SAMPLE VIDEO
MORE INFO:
* Automatically adapt to the model in line with OBD-II (vehicle automatic diagnostic system) plug and play models
* Shows the current speed
* Shows the speed of the engine, representative of light to reach the speed of scale, unit x1000 RPM.
* Shows the current temperature value of the car, when temperature reached 115 degrees automatic red alarm.
* The power of the HUD.
* Auto / Manual brightness adjustment, you can manually adjust the brightness according to their environment, up self-locking to automatic light adjustment, toggle down to manually adjust brightness, automatically save the setting.
* Shift indicator on. When the engine speed and vehicle speed reaches a certain percentage (such as 2000 RPM, the speed of 60KH / H inside), suggesting that shift lights, gear tips to save fuel consumption.
* Power cable with integrated design, full exposure and longer life.
* Tips switch gear. CVT automatic transmission car or cars do not need to use when you can close without prompt, press the 0 shows that off, it shows 1, that open.
* Tips for speeding when the need to use the alarm switch, you can turn on of off, it shows 0, indicating that off, it shows 1, that open.
* KM in the International System of Units unit of general use kilometers per hour.
* Voltage, fuel consumption, temperature V is the voltage, L-hundred kilometers liters (currently unavailable), C for Celsius.
* Miles of flat : Some countries use MPH as the speed measurement. HUD units for the miles you can switch display.
* Speed warning lights : Set off alarm in case of speeding, the speed that light up, and voice prompts.
* Instantaneous fuel consumption. In case of a speed, show hundred kilometers.
* Top speed record : Opened to the highest recorded speed, long press to clear.
* Set the alarm rate : Launched in the automotive state, long press the M key to display 0, you can set the value of a single segment 35-175 alarm : Long press M button to display the 1, then enter the multi-alarm state, respectively, in speed of 60, 80, 100, 120.
* Speed, water temperature, voltage switching : Click in turn show the speed, water temperature, voltage values.
* Automatic light-sensitive
Old Mar 25, 2012 | 03:56 PM
GTS Jay's Avatar
GTS Jay has a spectacular aura aboutGTS Jay has a spectacular aura about
Wrong link?
Old Mar 26, 2012 | 06:15 AM
Dennis C's Avatar
Originally Posted by GTS Jay
Wrong link?
What, you don't want an Etch A Sketch in your Cayenne?
Old Mar 26, 2012 | 08:11 AM
ciaka's Avatar
LMAO...I could have sworn I pasted the right link into this thread....corrected in top post already.
Seems to work..
Old Mar 26, 2012 | 08:50 AM
russnyc's Avatar
russnyc is infamous around these parts
I also see that Pioneer announced that they're going to be shipping one that also integrates Navigation - very cool.
Old Mar 26, 2012 | 10:57 AM
ciaka's Avatar
yes, the Pioneer did announce in 2010 a HUD like Navigation, which seemed really cool.
I am waiting for the True3D navigation, and if it comes with HUD interface, that would rock.
Here is what I am talking about:
What I was asking about originally though referred to HUD for vehicle telimetry, as opposed to nav.
Old Mar 26, 2012 | 12:30 PM
russnyc's Avatar
understood on the telemetry but figure once you have an aftermarket hud capability then it's a matter of deciding what to pump through it. meanwhile, that video of the NAV is off the charts!
Old Mar 26, 2012 | 02:45 PM
GTS Jay's Avatar
Well, Mit Romney has one, doesn't he?
Old Mar 26, 2012 | 03:34 PM
ciaka's Avatar
...actually I heard Joe Biden has it.
Old Mar 27, 2012 | 12:11 PM
cordsig79's Avatar
cordsig79 has a spectacular aura aboutcordsig79 has a spectacular aura about
Ron Paul was the acutal person you were thinking of....
Old Mar 28, 2012 | 04:43 PM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Wink
HUD is a great way to make it look like a 1989 Pontiac GTP
I honestly thing it would be a bit annoying. The cayenne is already a bit over the top as far as information on the screens! Do I really need the time to display in 3 spots?!! The speed is already in 2 forms.
Old Mar 28, 2012 | 07:17 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
You forgot temperature - how many outside temperature displays can you get at the same time? (Quiz..)
Old Mar 28, 2012 | 07:38 PM
Cole's Avatar
At least 2! An the radio station display in two spots too.
Old Mar 28, 2012 | 07:45 PM
ciaka's Avatar
2 outside temps, and how many inside temps?
PorscheEnthusiast
Nov 13, 2015 02:23 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
r_matt_6
Oct 8, 2015 06:07 PM
vr6tee
Aug 29, 2015 03:52 AM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
