Who has put a Cayenne on the dyno?
Old Jun 7, 2012 | 11:24 AM
GothamCayenne's Avatar
GothamCayenne is infamous around these partsGothamCayenne is infamous around these parts
I am scheduled to get my cayenne up on a dyno on wednesday (the 13th) and I need some expertise/experience on this. Last time I tried this we were not able to get readings as the car continued to self adjust the air suspension and loosened the securing straps, so instead of having the car run away on us we decided to cut our loses and call it quits. Is there some way to enter a dyno mode, I know that some mercedes have this feature, or maybe pull some fuses or something...? Help!
Old Jun 7, 2012 | 12:07 PM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
I would call Evoms
Old Jun 7, 2012 | 12:18 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
I would imagine that you should be able to either pull the fuse for the air suspension compressor (I do not know what else is on that fuse) or simply disconnect the air compressor at the electrical source. No compressor, no vehicle bucking. I am sure you will probably throw a code, but that can be cleared via Durametric if you have one.
If you want, I can check my 957 manuals to see where exactly the air suspension compressor is located. I know the tank is in the rear, next to the spare.
Old Jun 7, 2012 | 12:59 PM
s4treg's Avatar
s4treg is infamous around these parts
Perhaps a dumb question, but did you try just disabling the air ride by pushing/holding the toggle up? You can disable it for raising the truck (changing tires, working under it), without having to pull fuses, etc.
Old Jun 7, 2012 | 02:52 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
A second dumb question - this is a 4 wheel dyno? (Since otherwise you're gonna burn up the center differential..)
Old Jun 8, 2012 | 12:14 PM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
Disable the air suspension as mentioned above; likewise the AWD dyno part. No other changes are necessary. I've dynoed mine without incident.
Old Jun 8, 2012 | 12:43 PM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
Doesn't this automatically re-activate once you hit a certain speed?
Old Jun 8, 2012 | 01:00 PM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
maybe the way its hooked up, not to the body but to the suspension thats not going up and down at 70.
Old Jun 8, 2012 | 01:40 PM
s4treg's Avatar
Oh, does it? I know if you lower the vehicle to "loading level" it auto rises, but didn't know about he auto re-enable.
Glad I prefaced my response with "dumb question".
Old Jun 8, 2012 | 10:38 PM
roxboxxx's Avatar
roxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant future
It can be Done !
and this hideous thing (I hope its not someone heres ride !!!
Old Jun 9, 2012 | 03:10 PM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
This is mine in the dyno. (BTW, some dork stole this photo and is using it on eBay to sell software, I have tried all sorts of things to get him to stop using it, do use your own judgement buying Tuning software with this photo)
I don't understand the issue you are having. If the dyno is level the Cayenne shouldn't be trying to level itself.
The Cayenne will drop down through the settings as speed increases. So if you are starting at the middle ride height it would lower (and loosen the straps). If you start out at the lowest setting, it can only go up, (tightening the straps).
The lowest drivable height is essentially the loading level which it enters at 130mph. So start in the normal "low" setting and keep it under 130mph and it should stay nice and tight. If you start in the loading level it will try to raise back up until you get to 130mph.
Old Jun 10, 2012 | 08:34 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Cole ^^^ where did you dyno at? Looks like a 4 wheel Dynojet. Thanks! I was going to dyno mine with PSM off, in manual mode in 4th gear. What gear did you dyno in? 4th gear should be pretty close to 1:1. Oh and what were your hp/tq numbers?
Old Jun 10, 2012 | 08:38 AM
Cole's Avatar
That was at Mac Autosport in Parker. Nick has dunked several of my cars so I just let him do it.
Old Jun 10, 2012 | 08:39 AM
03EvoIII's Avatar
This ^^^yes if you are strapped to the lower control arms, then it shouldn't matter.
Old Jun 10, 2012 | 06:57 PM
Yes, it was indeed an awd dyno. I had the air suspension locked in the highest setting. I think it was in 4th, maybe it reached 130(?!) I'm not sure. Going to give it another try for sure.
