05 Cayenne PCM unit problem
Old Nov 4, 2012 | 08:46 PM
aaron9918's Avatar
aaron9918 is infamous around these parts
I got a 05 cayenneS. The PCM unit recently failed. I thought it was probably some wiring problem, and it turned out that I was wrong.
Saw some guy selling his unit which was taken out from a 06 cayenne. The part number is 7L5.035.192A. Mine is 7L5.035.191J.
Can anyone tell me if it fits in my car? Do i need to have the dealer reset the nav unit after replacing it.
Old Nov 16, 2012 | 12:38 AM
nooksack's Avatar
nooksack is infamous around these parts
I thought my unit failed too. Luckily all I needed to do is hit the reset code 1 4 8.
Old Nov 16, 2012 | 09:49 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
They should be interchangeable, but you will need to have the data copied off of your PCM unit, before removal, and then coded to the other unit once it's installed. I would try a reset first though if I were you.
pilotscottb
Sep 1, 2015 10:29 PM
murox
Cayenne 958
Aug 30, 2015 09:58 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
thegrillboy
Cayenne 958
Aug 22, 2015 09:24 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
