check engine light
Old Jun 29, 2005 | 02:38 PM
CayenneS2083's Avatar
CayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really nice
check engine light
Hey my check engine light came on today. I have 7,000 miles and my only mod is the fabspeed bypass pipes. Are the pipes causing this? I put the pipes in at about 2,000 miles and until now nothing had happened
Old Jun 29, 2005 | 04:11 PM
20C4S's Avatar
might be the coil that cause the cylinder miss firing. known issue form the dealer. that's a possibility.
Old Jun 29, 2005 | 05:53 PM
thanks, does that have anything to do with the pipes?
Old Jun 29, 2005 | 05:54 PM
20C4S's Avatar
that's a possibility as well.
Old Jun 29, 2005 | 11:39 PM
jamy85's Avatar
Boobie Stars
jamy85 is infamous around these parts
Dont know if this helps. But a while back some member had the same problem and if I recall correctly he had the fabspeed bypass pipes.
Old Jul 8, 2005 | 10:40 AM
What do you guys think I should do, should I take my car to the dealer with the pipes or do you think they will void the warrenty because of them. My dealer is champion motors, they are really good about mods.
Old Jul 8, 2005 | 10:46 AM
adiaz's Avatar
adiaz is infamous around these parts
they will not void the warranty because you have the pipes
Old Jul 11, 2005 | 11:07 AM
alirob's Avatar
alirob is infamous around these partsalirob is infamous around these parts
The check engine light on my 04 S has come on twice (with no mods). The first time (after about 10k miles) they reset it without determining the cause. The second time (about 5k miles later) they replaced the fuel cap. Now I'm at about 20k and no check engine light (yet).
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
The Oss
Aug 24, 2015 08:19 PM
