'08 Cayenne Turbo - pkg brake light/beeping
Old Nov 28, 2012 | 10:24 AM
SCSilvia's Avatar
SCSilvia is infamous around these parts
Hello - My '08 Cayenne Turbo's parking brake light(s) remain lit, and the alert continues beeping, after brake is released. Hoping to find a quick fix here, rather than trekking up to the dealership... Thanks in advance!
Old Nov 29, 2012 | 05:41 AM
Hal 2000's Avatar
Hal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really niceHal 2000 is just really nice
While pulling the release lever, stick your foot under the parking brake pedal and push it all the way up with the toe part of your shoes. See if that works. Probably common spring return problem.
Old Nov 29, 2012 | 07:51 AM
ciaka's Avatar
as said above, most likely your strut for parking brake lost pressure and is no longer forcing the brake pedal into its default position (all the way up). Since pedal 'sags', it trips the switch, appearing to show the brake is engaged. I wrote a how to on renntech.org, showing how to replace (really easy), and where I got my replacement.
Old Nov 29, 2012 | 07:44 PM
rymo926's Avatar
rymo926 is infamous around these parts
I stop using it because of that
cheap fix though. think $30 for part
Old Nov 29, 2012 | 10:19 PM
VIPNiSS's Avatar
VIPNiSS is infamous around these parts
what hal 2000 said..i had the same issue on my 2005.. strut on parking brake pedal was blown... had to use my foot to assist it all the way up until i got a new strut
Old Dec 1, 2012 | 09:31 AM
SCSilvia's Avatar
Thanks, Everyone!
Pulling the pedal up manually worked just fine. From what I understand, it's a common problem on the Cayennes. I've been quoted anywhere from $50-$100 for new strut.
Much appreciated!
Old Dec 1, 2012 | 09:42 AM
VIPNiSS's Avatar
Originally Posted by SCSilvia
Thanks, Everyone!
Much appreciated!
Order the dealer part here from this website below. It is only $20+ shipping and its super easy to do yourself.
http://www.ecstuning.com/Porsche-200...ake/ES1446705/
Old Dec 2, 2012 | 05:58 PM
ciaka's Avatar
Yes. Get it yourself for cheaper, read my diy on renntech.org, and replace free in a few minutes, then send me a check for the difference you saved. The diy may be on this site too, called brake pedal strut.
socialpro
Cayenne 958
May 18, 2016 09:58 AM
PelicanParts.com
Aug 20, 2015 03:00 PM
PelicanParts.com
Cayenne 958 Vendor Classifieds
Aug 20, 2015 02:59 PM
PelicanParts.com
Aug 20, 2015 02:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
