Rear window spray nozzle
Old Apr 12, 2013 | 04:11 PM
ciaka's Avatar
When you use your rear window spray nozzle to clean with wiper, does the nozzle spray a nice mist onto the window, or does it let out a stream of fluid that does not mist?
Wondering since I noticed my rear window spray does this and I wonder what I would need to replace to make this right.
Thanks.
Old Apr 12, 2013 | 04:30 PM
aspenone's Avatar
aspenone is infamous around these partsaspenone is infamous around these parts
Is it trickling out? if so get a pin or a needle and clean the nozzel should fix the problem
Old Apr 12, 2013 | 05:46 PM
ciaka's Avatar
It is not trickling out but shoots out in a jet like pattern, as if from mini water hose almost...no misting
Old Apr 12, 2013 | 06:59 PM
aspenone's Avatar
I think thats normal man
Old Apr 12, 2013 | 07:39 PM
ciaka's Avatar
Serious? Are those Germans crazy?
Old Apr 13, 2013 | 08:44 AM
aspenone's Avatar
haha yeah I think so...I will go outside and check mine and report back for you
UPDATE: mine seems to run down the rear window like small hose as the way you reported. Not jet no spray looks like a trickle or as if you left the hose on the ground and it has water pouring out hope this helps
Old Apr 13, 2013 | 11:39 AM
ciaka's Avatar
that's exactly like what mine does...serious? Could not do a better job to disperse the water there? Would have added what, 25 cents to the cost?
Is this proper operation or defective?
Originally Posted by aspenone
...looks like a trickle or as if you left the hose on the ground and it has water pouring out hope this helps
Old Apr 13, 2013 | 12:37 PM
Dennis C's Avatar
That's they way they were designed. The nozzle spits out a single stream of water rather than a wide spray pattern. There was a TSB for leaking nozzles on early Cayennes. I believe (it has been a while, so I don't remember 100%) that the original nozzles are black and the replacement nozzles are red.
Old Apr 13, 2013 | 03:30 PM
aspenone's Avatar
I think my nozzle is red...Im suprised about the nozzel everything else on this car is so well throught out and 110% Im very impressed with it
Old Apr 15, 2013 | 02:12 AM
digitaljok's Avatar
digitaljok is infamous around these parts
The single stream out the rear nozzle is by design. I brought it up at the dealer and even the SA was unaware that it was normal until it came back from the shop as-is.
Old Apr 16, 2013 | 07:29 PM
ciaka's Avatar
That's it...I'm sellin'!!!
Old Apr 16, 2013 | 08:28 PM
Bigbuzuki's Avatar
Bigbuzuki is infamous around these parts
I wonder if the 958 has a different spray pattern?
Old Apr 17, 2013 | 07:30 AM
ciaka's Avatar
Anyone with newer gen Cayennes that can comment on what they see from their rear window spray nozzle? On the 955 gen, it is not a spray nozzle but a squirt nozzle.
Old Apr 17, 2013 | 10:10 AM
aspenone's Avatar
Mine is a 957
Old Apr 17, 2013 | 12:31 PM
Dennis C's Avatar
I don't have a problem with the stream pattern on the 955. Just run the wiper for a couple of cycles with the washer squirting fluid on the glass and it does a fine job.
