Coolant pipe for v6
Old May 22, 2013 | 10:24 PM
Shawnliew88's Avatar
Shawnliew88 is infamous around these parts
Coolant pipe for v6
Hi guys! I'm looking to buy a 05 v6, do I need to look out for upgraded coolant pipe or is it just for the 4.5? Thanks!
Old May 23, 2013 | 07:22 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
That's only on the 4.5.
Old May 23, 2013 | 08:31 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Wink
Sorta.....
The V6 is actually a VW VR6 that is known to have the "Crack pipe" fail.Though, not as often as the one on the V8. It's essentially the same type of water pipe the V8 Cayenne has. You just don't hear about the the issue a lot on the Cayenne forums. Probably because most V6 buyers are not enthusiasts the way the V8 buyers are. So we simply see fewer V6 owners participating in the forums.
There is an aftermarket upgrade from several companies. One you may check out is "Gruvenparts" They bake a billet aluminum replacement.
Picture I found with GoogleFu of a stock VR6 crack pipe and an aftermarket metal replacement.
Old May 23, 2013 | 09:05 AM
XR4Tim's Avatar
I've seen leaky crack pipes on Corrados and GTIs, but never heard of a failure in a Cayenne. Maybe they're just not old enough yet?
Old May 23, 2013 | 07:06 PM
Thanks everybody for the feedback, I got another dumb question on the way and hope everyone don't mind. Does the body kits on cayenne fit all trims of the same generation? Like the other Porsches ? Thanks again!
Old May 23, 2013 | 07:51 PM
Cole's Avatar
Wink
Dunno.. I just put a new factory crate motor in my Eurovan (24v VR6 similar to the Cayennes) and just put a new factory plastic pipe on it. The first one lasted 154k.
I don't really know how often, if ever, they fail now. I was just simply pointing out that technically the V6 Cayenne still has a plastic coolant pipe that has had problems on similar motors.
Old May 24, 2013 | 11:18 AM
XR4Tim's Avatar
Yes, with the exception of front bumpers - Cayenne Turbos need the larger openings for the intercoolers. If you're referring to something like the Sport Design package, then yes, it will fit all trim levels.
Old May 25, 2013 | 03:28 PM
So I assume the turbo bumper will fit good on it too?
Old May 27, 2013 | 06:30 AM
Cole's Avatar
Yes.......
Saint Ari
Jan 17, 2022 09:22 PM
Rguy
Apr 12, 2020 11:11 PM
Yogi911
Sep 9, 2015 08:20 PM
