Oil Change ??
If you have a V8 Cayenne--a CS or CTT--the pan has 2 oil sumps with a drain plug in each, both plugs look the same. My experiance with a 2006 CS if you put in the recommended 9 quarts of oil it will be slightly overfilled. I usually start with 8 quarts and add enough after running for a while to bring it up to the full mark.
Apologies for reviving this thread, but i just changed my oil out yesterday.
Both the lower and upper drain plugs were torqued so tight last time, i stripped them trying to get them out. Finally got the lower one out, and drained all the oil, but had to give up on the upper one because of the lack of clearance.
My question is, i only filled up 8qt + some in the filter housing, and the dipstick already reads above max. Has anyone else experienced this? I'm thinking this is possibly because i didn't drain out of the upper plug.
It was late last night when i finished, so will take her out for a spin today and recheck the level and see if it looks good.
I would say it was just past the ridge line that denotes the max cutoff.
Awesome thanks, will check it out this evening and update accordingly.
