Going to look at a 2004 955 Turbo on Friday. Anything I need to look out for?
Old Nov 24, 2015 | 09:58 AM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
Problem areas? It has 85,000 miles. Thanks for your help! This will be an occasional family hauler.
Rich
Old Nov 30, 2015 | 07:46 PM
Zuffenhausen955's Avatar
Zuffenhausen955 is infamous around these partsZuffenhausen955 is infamous around these parts
1) Coolant Pipes replaced?
2) Cardan Shaft done?
3) Coil packs recalled?
4) Check power steering pump
5) Fuel Filter flange done(check rear carpet, if cut)
Those are the five most pressing issues....
Old Nov 30, 2015 | 09:43 PM
ciaka's Avatar
he got pretty much important stuff covered.
I would also look for creaks/sounds from car as you drive it harder than just put putting. Some develop annoying sounds when you drive/turn.
Check how much pads/rotors are on there left too. If about to be replaced, you are looking at about $700-800 in parts if DIY. Shop will take more.
I would have it scanned by a Porsche shop too, to see if it has any codes that need addressing asap too. Generally, taking to a Porsche shop is very highly recommended if getting any Porsche (IMO).
Good luck
DrJ991turbos
Nov 20, 2015 02:47 PM
speedracer800
Nov 16, 2015 06:47 PM
saphgreyc63
Oct 30, 2015 11:21 PM
DrJ991turbos
New Member Introductions
Oct 28, 2015 03:08 PM
zwill0412
Cayenne 958
Oct 28, 2015 01:32 AM
