Cayenne 955 heating question
Old Apr 13, 2016 | 11:16 AM
Fuzzo's Avatar
Fuzzo is infamous around these parts
Hi guys
Had my coolant reservoir replaced by the dealer last week and since then I have been noticing that it gets hotter than it did before.
Very rarely would my temp go beyond the center mark (80) and today with slow driving in the hills, it went almost to the 3/4 point, just a bit less than 100.
It comes back down but I'm a bit worried because it never has gone up that high before.
Any suggestions or advice. I've been reading some threads where people say it's normal.
Old Apr 13, 2016 | 03:28 PM
Porscheman33's Avatar
Porscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud of
My Mercedes does this a lot... I think its normal. I never looked at the Cayenne.
Old Apr 14, 2016 | 03:52 AM
gh0stman's Avatar
gh0stman is infamous around these parts
Is the expansion tank filled properly? You could have saved a bunch of money doing it yourself. Mine split in two, bought a new part, put it on in about 45 minutes.
Old Apr 18, 2016 | 11:59 AM
Eger's Avatar
Eger is infamous around these parts
Temperature between 80 and 100 is considering as normal according to driver's manual. I'm sure it used to be like that on your Cayenne before coolant tank replacement, you just did not pay attention. My advice - to keep a/c running in auto mode - it optimizes operation of coolant system as well.
Old Apr 19, 2016 | 12:16 AM
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
If it's getting excessively hot it could be they either didn't fill the system back up enough or there could be air trapped in it somewhere.
Old Apr 20, 2016 | 07:19 PM
KTI's Avatar
KTI
5 Year Member
KTI is infamous around these parts
Don't use the instrument cluster gauge, their for reference, not accuracy.
Use an OBDII reader that has that function to read the temp. Either a Durametric or other scanning device.
Supposedly its normal to run up to 235F. My cayenne hovers around 199-225F depending on road conditions.
I use this to monitor my coolant temperature. You can also set alarms so if the temp goes above or below your set value it will notify you.
I also use it to monitor my live MPG, average MPG, when to change oil, voltage etc.
http://www.ultra-gauge.com/ultragauge/
Old Jul 25, 2016 | 04:25 AM
Fuzzo's Avatar
thanks all... found all this happens only when i don't run the AC
with the AC on, the meter stays put at the center.
Duff0000
Jul 11, 2016 08:55 PM
GT650-25
Apr 18, 2016 09:51 AM
Gene G
Apr 11, 2016 10:54 PM
Jeff_335i
Apr 8, 2016 09:22 PM
