LED Reverse lights????? Help
Old Apr 26, 2017 | 05:14 PM
  #31
Porscheman33's Avatar
Porscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud ofPorscheman33 has much to be proud of
Originally Posted by Domino
There is one really cheap fix for these crappy cheap LED's. You will need at least some rookie soldering skills, a pair of original (non-LED) bulbs, few meters of wire. Just solder your original bulbs in parallel circuit with your LED's and put them somewhere they cannot set your car on fire. Not recommended to use this fix for constantly-on lights, because your classic bulbs will get really hot over time and that can make some permanent damage to your car. Downsides - you'll have to cut into your lighting wiring. Upsides - you have your LEDs running without errors.
The ECS ones aren't cheap, they work great in my Vert! I have LED reverse in my 4 door Audi too, amazing! I can't solder, I may just take it to a shop to have this done lol
Old Apr 27, 2017 | 04:03 AM
  #32
Domino's Avatar
Domino is infamous around these parts
Naah, man. It wasn't meant to particularly your bulbs. That was about "crappy cheap LED's" that don't have canbus resistance modules and low quality matrices. Btw, any man should know how to solder wires. Starter kit is about 5$. YouTube is the way to start.
Old Apr 27, 2017 | 06:09 PM
  #33
My Luck I'll some how end up setting my truck on fire... Youtube has helped me greatly, its also cost me alot of money that I've spent on fixing because I broke something
Old Apr 28, 2017 | 04:11 AM
  #34
Domino's Avatar
Just type in ebay search 1156 LED canbus error free. Enjoy. Eventually one of the hundreds will work.
Old Apr 28, 2017 | 07:34 AM
  #35
Legit so annoying taking the tail light out over and over again lmao.
REDNOSEGT
Bentley
25
Feb 12, 2024 06:39 AM
flatsixing
Dec 2, 2023 12:47 AM
mep1811
Cayenne 958
14
Oct 13, 2016 08:34 AM
MoNas
Apr 23, 2016 04:52 PM
