Four wheel drive system faulty
Old Dec 31, 2018 | 09:53 PM
Bazoora gamer's Avatar
Bazoora gamer is infamous around these parts
Why did you take the picture while driving
Old Jan 30, 2019 | 07:22 AM
ciaka's Avatar
My bets are on this too. Stepper motor acting out due to age. Most people just ignore the fault that occurs randomly.
Originally Posted by Bigbuzuki
Transfer case motor is playing up. Quite common.
Old Nov 11, 2019 | 02:40 AM
Paulgenito's Avatar
Paulgenito is infamous around these parts
Cayenne s 04 4x4 faulty. I change my 2 batteries and I still have the faulty sign
My car is not running properly and it is very slow when the l
the faulty sign on is. How do I fix that. I’ll send the picture.
4x4 faulty light
Why is the light on?
Old Apr 2, 2020 | 12:29 PM
jayundy's Avatar
jayundy is infamous around these parts
Were you able to solve your issue? My '04 is doing the same thing with the same error lights and messages (4 Wheel Drive Faulty, PSM Failure Workshop, Low Range Lock On, and the lights on the dash and range selector on the console). It is stuck in low range and hesitates and lunges in both forward and reverse. I have removed the transfer case motor, but haven't purchased a replacement as I don't know if that is the problem for sure yet or not. Curious what your problem and solution was. Thanks.
