2004 Cayenne s
Old Sep 24, 2018 | 05:30 PM
lexiJames's Avatar
lexiJames is infamous around these parts
2004 Cayenne s
Apologize if I am not posting in the proper manner,
I had the vehicle sitting for the past 3yrs working on it when time allows. Began driving 3 weeks ago, on occasion while turning left or right at slow speeds I have a slight thumping sound under passenger area and a wobbly feeling from the tire as it rotates. I do not know if the tire is actually wobbling I also have which I believe to be unrelated the faulty 4wd and Psm failure. I state unrelated because the lights showed up years ago, and this is a new problem. Before tearing things apart do I have any opinions or suggestions.
Thank you
Old Feb 9, 2019 | 03:36 PM
Dariopks's Avatar
Dariopks is infamous around these parts
Thank you
Have you checked the ball joints? I would raise the car and check all the suspension / steering components. Joints and bearings and tie rods. If they are good, I would get a good alignment done.
Old Feb 10, 2019 | 10:46 AM
lexiJames's Avatar
I thank you for your reply, I have concluded that it is traction control, just a little difference in tire pressure has really caused a issue. From sitting for so long tires did lose pressure and they have not sealed properly when refilling with air. As long as I'm maintaining equal pressure in the front I have no issues. The vehicle has 265000 miles on it and it still runs very strong I have occasional warning lights telling me to take it to the shop. But I believe it's the garage telling me they want some money
Proximo
Cayenne 955/957
17
Sep 30, 2010 06:30 PM
detailersdomain
Cayenne 955/957
22
Jan 1, 2007 04:22 PM
