Removing intake and troubleshoot coolant leak
Old Jan 20, 2019 | 07:58 PM
ciaka's Avatar
I plan to remove intake to pd coolant leak that recently occured on my cayenne turbo.
Have few questions and advice from those in the know. Thank you very much.
My CTT had coolant pipes done already and replaced with the metal ones. Yet, another coolant leak happened so deciding to do on my own since mechanic obviously either did job wrong, or neglected to tell me of some other part that fails routinely, and now I have to take this apart again.
1. Do I need to get new intake seals (two of them) whenever removing intake on cayenne turbo
2. In addition to cooling pipes, what other pipes routinely fail under the intake, so I can keep an eye out.
3. Are there parts I can get that have longer life, so I dont have to redo yet again.
4. Any ohter advice while doing this for my car (tips, hints, items worth changing while you are there, etc)
5. Heard there are some smaller pipes that are plastic but fail, and can be purchased metal (not sur if t-pipe or angled, etc), but if you have info withg pn, url, I will really appreciate it.
thank you.
Old Feb 21, 2019 | 09:45 AM
ciaka's Avatar
To complete this thread, actually it is pretty easy. Takes some time, but easy for sure.
I used coolant pipes replacement manual from ECS tuning, which you can find here.
Follow it and it will guide you step by step, to remove the intake and afterwards to put it back on. Make sure you replace the gaskets (2 of them), before you put the intake back on.
If you need to do coolant pipes, not too hard either but does take time too. Good luck.
Old Feb 15, 2020 | 08:50 AM
jzchen's Avatar
5 Year Member
jzchen is infamous around these parts
Thanks for sharing this find ciaka. I'm afraid we didn't even have a Porsche at the time you posted this, let alone any answers for you. Now onto finding where the coolant is disappearing on our NA V8......
BTW-. There's definitely some rodent/mouse poop around those intake ports in ours as well....
ciaka
Cayenne 955/957
May 4, 2019 09:51 AM
ciaka
Cayenne 955/957
Jan 29, 2019 09:28 PM
Timothykee
Dec 27, 2017 08:23 PM
VIPNiSS
Cayenne 955/957
Oct 29, 2012 08:37 AM
oneill1227
Cayenne 955/957
Oct 10, 2012 05:52 PM
