2008 Cayenne GTS Audio Question
Old Aug 27, 2019 | 12:05 AM
Hedge-Hog's Avatar
Hedge-Hog is infamous around these parts
Hi all,
Firstly, I apologize if this has been covered many times. I did a search and found older posts or not directly covering my questions or my may have missed the posts altogether. Is there a sticky somewhere for aftermarket audio replacement?
Anyway, I am doing a mild upgrade to my PCM 2.1? head unit. Currently, I have replaced the unit with:
- Pioneer AVIC-W8500NEX (seems to work fine)
- Scosche LPPE15 harness kit (steering wheel control's mute doesn't work and the Man button does nothing also; it also does not provide retained access power).
- Metra 99-9604b Dash Kit...fits fine.
- Metra 40-EU10 Fakra antenna adapter (not sure if I should get the dual Fakra ones).
1) I'm wondering if others have tried/recommend any other smart harness brands? I found Metra / Axxess Interface AX-PO90032 but they claim it's not for my year (up to 2007). They suggest the AX-PO90042. The difference that I see are the connectors. The former has the 16 & 20 pin ISO harness and the latter provides the 40-pin Fakra connector. My OEM head unit is the 16 & 20 even though mine is an early model 2008. I use that from the Scosche kit also (as mentioned it does not have R.A.P.S. so it powers off the deck when I turn off the motor).
2) I plan to replace the speakers first. Are the speakers just straight replacement or are they actively crossed-over? And does any have fitment specs (depth and diam)? I see online searches list 6.5" as well as 5.25". The front woofer looks like a very shallow mount too.
Thanks again in advance.
Regards,
Hedwig
F15DOC
Cayenne
23
Oct 4, 2016 03:13 PM
Yocto
Cayenne 955/957
Jan 15, 2014 09:18 AM
mylai996
Cayenne 955/957
Nov 30, 2010 04:43 PM
M3 GIRL
Cayenne 955/957
Mar 3, 2009 09:38 PM
