Cayenne 957 after market radio
Hi all and compliments for 2021 to you all...
I’m looking for a replacement radio including Apple car play, Google Maps etc.
mid anyone has any recommendations for which unit to look at I’d appreciate it. I’ve been looking at Pioneer, Kenwood and some Android Auto versions... must have at least reverse camera and panoramic side and front camera options would be a bonus.
if possible has anyone managed to get tyre pressure monitoring equipment interfered with the radio and possibly vehicle computer read outs (fuel consumption, mileage, temperature, oil pressure etc) to the radio...
TIA and keep safe from this wretched COVID!
If you have the "blows" system, then literally everything will need to be replaced as the factory deck will not be able to make the factory amp work AND if you add your own amp or use deck power, the speakers will all need to be changed to increase the Ohm rating on the speakers to match the aftermarket deck/amps. I like the high end Pioneer decks the best. I used this one (
) in my last Cayenne and it did a great job. I also have the Pioneer AVH 4200 NEX and it has all kinds of problems. Avoid that one. I have the top end Kenwood DDX8706S, in another car, but it seems to run a little slower. It's a pretty time consuming job, but well worth it. Crutchfield is a great resource to find out what works with your model. Good luck!
