Limit Exceeded
Old Sep 27, 2006 | 02:21 PM
Triple B's Avatar
Triple B is infamous around these parts
Limit Exceeded
Quick question for you guys....I have a 2005 Cayenne that we bought about a month ago. On the Radio/Navagation unit while the raido is on the screen goes black and "Limit Exceeded" pops up for about 2 seconds and the the main screen returns. The radio does not turn off during the Limit Exceeded 2 second.
I did not see any thing in the manual and it is still under warrenty but i have not had time to take it to the dealer.
Thanks for any advice
Old Sep 27, 2006 | 04:02 PM
MeanMachine's Avatar
Someone has set a speedlimit on your PCM, I will try to figure out how to disable it by tommorow , I hope the otherguys could tell you how to disable it as soon as possible
Old Sep 27, 2006 | 04:18 PM
Triple B's Avatar
Very cool I will look in the manual tonight to see how to disable that tonight.
Thank you very much I was worried that it had something to do with the radio / nav.
Thanks Again
Old Sep 27, 2006 | 05:44 PM
No, Dont worry its nothing serious you just have to fiddle with the PCM to get it switched off nothing technical
Old Sep 27, 2006 | 10:34 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
It's not in the PCM, the setting is in the instrument cluster computer. Just go into Menu and go to limt, and either turn it off or set it to max, either way will get rid of it.
Old Oct 3, 2006 | 11:30 AM
Triple B's Avatar
Thanks for the help MM & speeddem.
It was in the Trip Function. I guess you can put a time limit to remind you to pull over and take a break.
Old Oct 4, 2006 | 12:22 PM
kdubb's Avatar
kdubb is infamous around these parts
hmm, mine says that too... been wondering how to fix it. thanks !!
Old Apr 7, 2014 | 05:54 PM
kenlovorn's Avatar
kenlovorn is infamous around these parts
So I have the same problem on a 2004 cayenne s.... But when I go into the settings it only gives me back, vehicle info, and settings. I checked all the settings and even put it at factory settings and can't get the limit option. Any ideas for me?
Old Apr 7, 2014 | 06:09 PM
rymo926's Avatar
rymo926 is infamous around these parts
Were you driving at the time. Not all settings are available if car is moving.
Old Dec 15, 2018 | 10:18 AM
Ian Phillips's Avatar
Ian Phillips is infamous around these parts
Answer
Go to trip on the PCM then scroll to limits the uncheck the tick box
bingo all sorted did mine this morning
Old Dec 17, 2018 | 06:43 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Not time - speed.
albert@velosdesignwerks
997 Vendor Classifieds
Sep 9, 2015 03:51 PM
997 Turbo Vendor Classifieds
Sep 9, 2015 03:49 PM
996 Turbo Vendor Classifieds
Sep 9, 2015 03:48 PM
996 Vendor Classifieds
Sep 9, 2015 03:40 PM
