Anyone know how to change the fog lights?
Old Nov 6, 2006 | 05:11 PM
Oweyea's Avatar
Cab Lover
Oweyea is infamous around these parts
Hey guys,
I bought a pair of amber lights for the fog lights but I have no clue how to get to the fog lights. It looks like a major PITA. Would someone please put my worries to sleep and tell me their is an easy way to replace the fog light bulbs!
TIA,
Rob
Old Nov 7, 2006 | 11:34 AM
TCM's Avatar
TCM
TCM is infamous around these parts
You need to remove all the lower undertray panels and then reach up in there are change them. Not hard to do, just a PITA and time consuming. Hope this helps.
Old Nov 7, 2006 | 01:24 PM
kooser's Avatar
kooser is infamous around these parts
"If you look under the front where the fog light is, you'll see the thick torson bar that goes across from one side of the wheels to the other. Right in front of the torson bar is a squarish plastic molding. It is held on by philips head screws. It is the only piece under the car in this area that has Phillips head screws. There are five screws total...three underneath and two more in the fender well. Remove these five screws and then the molding. This will give you full access to change your fogs as well as side markers. Turn the fog light counter clockwise (looking from the back of the lights) to loosen.
Makes sense they designed it like this to make quick change of bulbs easily accessible. It takes only minutes to remove these screws. I did it with my steering wheel straight. There is room in the fender well for a short Phillips. You can always turn the wheels for better access."
Hope this helps
Old Nov 7, 2006 | 05:01 PM
Oweyea's Avatar
Cab Lover
Thanks for the info kooser. I'll try it tonight and see if I can get it to work. I'll take some pics of the process so others can see it.
Rob
Old Nov 7, 2006 | 05:54 PM
Oweyea's Avatar
Cab Lover
So Koooser is correct. I was able to easily access the fog light as per his specifications. the only problem I had is I ordered the wrong frigin lights! I ordered the H2 like the 996 fog lights but the Cayenne takes the H11. So I'll post some before and after pics for you guys when they send me the "right" bulbs.
Thanks for all the help.
Rob
Old Nov 7, 2006 | 08:32 PM
kooser's Avatar
Oweyea,
Try these Hoen ones (pull down to the bottom of this page for the Porsche Cayenne Section) http://www.hoen-usa.com/guide2.htm
Pretty close matchup with the factory HID/Xenon headlights - they are H11s
BTW, how pissed were YOU when you found out you had the wrong bulbs. I can't STAND it when that sh*t happens!
Old Nov 7, 2006 | 08:34 PM
kooser's Avatar
Sorry, my bad, forgot that you wanted amber ones.
Old Nov 8, 2006 | 10:55 AM
CayenneTurbo77's Avatar
CayenneTurbo77 has a spectacular aura aboutCayenneTurbo77 has a spectacular aura about
Does anyone know if those H11's will fit in the Gemballa lower bumper fog lights??? I want to change them to a xenon look instead of the regular halogens they come with.....
Old Nov 9, 2006 | 11:23 AM
gmoney's Avatar
H11 in yellow = Hoen Endurance www.hoen-usa.com
Nothing worse than having all the parts off the car, trying to get something to fit and it doesnt! Been there with coil overs on my old BMW...not fun...but only myself to blame for not checking the box!
Old Nov 17, 2006 | 09:45 PM
JDN17's Avatar
JDN17 is infamous around these parts
Originally Posted by kooser
Oweyea,
Kooser- Are you using the Hoen bulbs for the fogs? Did you replace the cornering lights also?
Old Nov 17, 2006 | 10:11 PM
kooser's Avatar
Yes I am - they are a pretty good match with the xenons.
I did order the cornering light bulbs too - but beware - they did not have the exact prong configuration even though Hoen's website claims they are the correct bulb for that application.
If you find something that works let me know because i don't particularly care for the color (spectrum) of the cornering lights and how they look bland next to the xenons and Hoen fogs.
COBB Tuning
Jan 1, 2025 09:02 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
00aston
Aug 27, 2015 12:01 AM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
