How do you lower a Cayenne?
Old Jan 2, 2007 | 03:33 PM
GT3Racerich's Avatar
GT3Racerich is infamous around these parts
Question How do you lower a Cayenne?
Thinking of getting a Cayenne. What does it take to lower one. Are there different ways to go about it? What are the aprox. costs?
Thanks in advance, Rich
P.S. If anyone has any photos of lowered Cayennes that you could post I would love to see them.
Old Jan 2, 2007 | 11:10 PM
ThisFlyGuy's Avatar
ThisFlyGuy is a jewel in the roughThisFlyGuy is a jewel in the roughThisFlyGuy is a jewel in the roughThisFlyGuy is a jewel in the rough
you should pm 20c4s (sp?)........aka the guys at Lucent Motors...
Old Jan 2, 2007 | 11:29 PM
Cognac's Avatar
Cognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant futureCognac has a brilliant future
get cayenne first than think about it...
Old Jan 3, 2007 | 12:00 AM
alex911s's Avatar
alex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond reputealex911s has a reputation beyond repute
yup then let us know if it's steel spring or air suspension
Ok i'll be nice..lol
Cayenne's with pasm/air suspension u can use air suspension module..
or replacing the links with a shorter one.
With Steel spring it;s just like any other car either lowering springs or
coilover setup
Old Jan 3, 2007 | 03:07 PM
SMR's Avatar
SMR
SMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the roughSMR is a jewel in the rough
a ctt has AIr stock right..?
Old Jan 3, 2007 | 03:58 PM
alex911s's Avatar
yup........
Old Jan 3, 2007 | 07:08 PM
emissary's Avatar
emissary is infamous around these parts
Could someone please elaborate more as to what this actually entails? Are all air suspension levels effectively lowered, or is there a new "way low" level? How is the module installed? Are some products better than others? Thanks!
Old Jan 3, 2007 | 07:12 PM
SMR's Avatar
SMR
yup........
Just confiming, i hope i will be owner off one soon..
Old Jan 4, 2007 | 10:28 AM
turbo'S''s Avatar
turbo'S' is infamous around these parts
Adjustable Ride
I have just received the replacement links for lowering my CTT and will fit them in the next couple of days. They replace the originals and are adjustable to suit. The longer the bar the lower the height.
I will post feed back and pics once done.
I got them from John at www.adjustableairride.com.
Cheers.
PS I am in no way associated to the company. Just hope to help out.
Old Jan 11, 2007 | 11:59 AM
turbo'S''s Avatar
Adjustable Ride
I have just fitted new adjustable linkages to my CTT and first attempt has dropped the car way to low. It is certainly effective and I can see that it will be pretty straight forward but will have to shorten the linkages to raise her back up again. It is virtually on the bump stops and negative camber is extreme.
Will report back tomorrow when I re-adjust then post pics.
Old Jan 11, 2007 | 10:51 PM
alex911s's Avatar
Gives you a lower , low level setting and higher offroad, here's the
techart as as example...I kinda like the sleep mode
You just swap the stock module with the new one, it's located by your cd changer on the right rear compartment..
Lower on the road, higher off road
Up to 80 millimeters lowering on the road and up to 70 millimeters lifting for heavy-duty off road operation: The new TechArt Sport air suspension module from TechArt Automobildesign further expands the scope of the Porsche Cayenne.
The TechArt Sport suspension module, which is offered for a retail price of 1 682 Euros for all Cayenne models with air suspension, can be easily installed by every workshop due to its plug-and-play technology. The standard control module can be installed again anytime.
In parking position the Cayenne customized by TechArt "sleeps" in lowest position. When the engine is started the SUV automatically lifts up to standard level. By using the standard suspension level adjustment wheel on the cockpit the Cayenne can be alternatively lowered by about 80 millimeters or lifted up to 70 millimeters to reach a bigger ground clearance for off road driving. The computer-controlled TechArt Sport air suspension module is designed to provide enough residual spring travel to guarantee an optimal driving safety and to preserve the ride comfort of the car.
Old Jan 12, 2007 | 09:43 AM
gezi999's Avatar
gezi999 is infamous around these parts
This is the TechArt lowering module which replaces the original module.
Special effect is that when you lock the car while you are in low leve
it goes down in loading level for parking!
For further information contact CEC or lucentmotors.
Jan from TechArt HQ in Germany
Old Jan 13, 2007 | 09:31 AM
Thanks for the info guys.
Rich
dgreen78
Feb 29, 2016 11:28 PM
Yellopeter
Cayenne
Oct 9, 2015 11:20 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
