Gas filler lild and rear hatch, no go--anyone?
Originally Posted by allenjdmb
Both are dead. Haven't experienced this on any of my other Cayennes. This one has entry and drive--reckon there's anything different to do with that? Are those switches fuse controlled, perhaps? Any help appreciated, thanks.
Kevin H
Excat the same problem
Hello there i have the same problem, i took it to the dealer and they said i need to remplace the front control module, since i have to order it and leave the car in there for two weeks i refure and drove away, if you solve the problem please let me know. i will order the damn control and do it myselft, dealers love to keep our cars. Regards!
There is no "front" control module in a Cayenne, maybe they meant the front door module. If this is the case, it is not just a simple replacement issue, there are certain things that have to be transfered from the old module such as coding, this is done with the PIWIS tester, no other way to do it. After the new module is installed and coded properly, you must perform a "basic door coding" and then lastly in the instrument main menu, you must reset the door settings or else the rear hatch will work opposite (don't ask how I know this)
Unfortunately, unless you have the luxury of a personal PIWIS tester, there is no way a do-it-yourself guy can perform this repair, not even a trusted independant tech has the ability. These cars are getting so complex that if the person repairing it is factory trained, there is almost no hope of a fix.
Kevin H.
Well my friend they remove the switch from another cayenner and everything goes back to work, simply like that, but i can`t be sure that this will apply to everybody else. cheers.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Serg124
Sep 10, 2015 05:27 AM
