TPS or No TPS? That is the question....
Old May 19, 2007 | 04:43 PM
BD 997's Avatar
BD 997 is infamous around these parts
Thinking of pulling the trigger on 23" Rinspeeds from WheelsExperts.... but I am debating if I should order them with TPS or not... will I get any warning lights if I change the factory wheels with wheels that does NOT have TPS... Thanks!
Old May 19, 2007 | 05:12 PM
emissary's Avatar
emissary is infamous around these parts
Assuming that the 2008 TPMS system is the same as the pre-2008 TPMS system (which I believe is a reasonable assumption), if the TPMS system is active and sensors are not present on your wheels, you will receive an error message (complete with loud beeps) after approximately five minutes of driving. You can turn the TPMS system off, although you will always get a "TPMS" system off warning (with no beep I believe) when you start the car.
I would highly recommend the TPMS sensors in larger wheels due to the fact that is very difficult to visibly see when your tire is low on air because of the slim tire profile and stiff sidewalls. I have them on my 22-inch wheels in my CTT.
Old May 19, 2007 | 05:39 PM
BD 997's Avatar
cool... TPS is it. thank you!
Old May 19, 2007 | 07:17 PM
emissary's Avatar
On a side note, I found that TireRack had the best prices on the OEM sensors (they're Borsch parts) should you need to source them.
Old Mar 30, 2011 | 09:49 PM
Imsooskinny's Avatar
Imsooskinny is infamous around these parts
where is everyone buying their tps sensors? my summer wheels are going on soon!
Old Mar 31, 2011 | 01:38 PM
RobsCountach's Avatar
RobsCountach is infamous around these parts
I vote NO. I de-activated mine.
Its preset WAY too high. No way that 45lbs in the rear is required. Crazy.
Old Mar 31, 2011 | 07:42 PM
how do you deactivate it? is it in the tire options?
Old Mar 31, 2011 | 08:15 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Also know that 2003-2006 is first gen TPMS, and 2008-up is second gen TPMS. Not compatible.
Old Mar 31, 2011 | 08:17 PM
Yes.
Main Menu > Tyre Pressure > Settings > System
Old Mar 31, 2011 | 11:43 PM
Yes.
okay thank you! i hope this is the same with the 08-09. ill check it this weekend!
Old Apr 1, 2011 | 09:41 AM
Yeah, that I can't guarantee. Feds made TPMS mandatory in '08 (or thereabouts), so it might not be in Menu.
Regardless, Dealer (or anyone with proper S/W equipment) can turn it off.
Old Apr 11, 2011 | 09:30 PM
cannot turn it off on the 09 models
Old Apr 12, 2011 | 11:53 AM
lnferno's Avatar
lnferno has a spectacular aura aboutlnferno has a spectacular aura aboutlnferno has a spectacular aura about
If you have OCD, do not get TPMS LOL It will drive you nuts if your tires aren't matched in terms of the air pressure! haha
Old Apr 12, 2011 | 11:57 AM
Cole's Avatar
Cole is just really niceCole is just really niceCole is just really niceCole is just really nice
Thumbs up
LOVE my TPMS.
Honestly think you have to be an idiot to disable the system.
We drove from Sante Fe, NM to Denver, Co a few years ago in our Audi A6 Avant. Filled up with gas that morning and checked the tire pressures since we would be on the road for 5 hours. Tires were only about 2 months old.
3 hours after checking the tire pressures we lost a tire at 85 mph. Must have picked up a nail or ??. Driving on it that fast and it going low detroyed the tire. The only thing left of the tire was the steel belts of the side walls.
With the low profile tires it was hard to tell if it was going low with the cross winds on the highway. Spent the next 4 hours driving on the stupid space saver spare. Totally sucked to have to get my dogs and all of our stuff out of the back of the car on the side of the freeway to access the spare.
If we had known it was going low we could have stopped and fixed it somehow before the blow out. Could have been a life changing, dying, event.
I would rather put up with the warning lights and chimes for running *my* pressure settings, than not have the system on at all. Not to mention it helps me get longer tire life and save money by knowing when one tire is running low all the time.
dog4delta
Jan 28, 2016 09:20 AM
porsche42
Aug 28, 2015 06:53 PM
