How to change brakes on 05 Cayenne S
Old Jul 5, 2007 | 09:28 AM
pigcorn's Avatar
pigcorn is infamous around these parts
Anything I need to consider on my Cayenne S with 20,000 miles when it comes to changing the brake pads? Never done it on a Porsche Cayenne before. Also thinking of changing the calipers to the Red ones like on the Turbo.
Thank you
Old Jul 5, 2007 | 09:38 AM
TCM's Avatar
TCM
TCM is infamous around these parts
It is pretty straight forward. You just need to remember that brake hardware is also required (comes with pads I beleive). Also be sure to check the rotors for thickness as many times they will need to be replaced as well. Hope this helps.
Old Jul 5, 2007 | 12:34 PM
capt601's Avatar
capt601 is infamous around these parts
really easy to do. just follow the instructions for the 996 on renntech.org, and it will be a breeze. i didn;t replace the rotors this time, but probably will next time. they look like they will be a little more tricky as the caliper bolts to remove are around 200 ft/lbs
Old Jul 5, 2007 | 04:58 PM
pigcorn's Avatar
Thanks will do. Do I wait for a "brake" light or message from the PCM? Also any thoughts on the best place to purchase them online?
Old Jul 5, 2007 | 08:04 PM
capt601's Avatar
I had ordered the parts and the brake light jsut came on, so it happened to be good timing. but if you were told they needed to be changed why not jsut do it, if not wait for the light.
I bought the pads from sunset imports in Oregon. Best prices for Porsche parts around, and no taxes. They are great to work with. http://www.sunsetimports.com/porscheatcost.php
Old Jul 5, 2007 | 08:43 PM
pigcorn's Avatar
Great Thank You, any idea of generally how much it costs to get brakes done at dealer...I want to feel good about what I would be saving :-)
Old Jul 5, 2007 | 09:37 PM
SoCal955's Avatar
SoCal955 is infamous around these parts
Anywhere between $600-$800 depending on the stealer!
Old Jul 6, 2007 | 12:45 AM
capt601's Avatar
I was thinking I was quoted from $850-1000, but anyways it is much cheaper to do on your own.
Old Jul 7, 2007 | 02:44 PM
LIL RAJA's Avatar
LIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant future
keep me posted. i thought it was much more expensive than 1k for the caynne brake change but it sounds good to me now.
raja
Sales@RSW
Sep 3, 2015 09:34 AM
00aston
Aug 27, 2015 12:01 AM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
